Subcategories
    125 Topics
    A
  • 211 Topics
    robskiR
    @GiovanniCaenazzo disconnect M5Dial press and hold boot button at the back ofM5Dial - in the middle of Stamp Controller - it is very gentle switch connect M5Dial to USB M5Burner should detect com port in boot mode
  • 11 Topics
    A
  • UiFlow (web) requests wrong firmware update
    4k Views
    ZontexZ
    Hello, are you experiencing same issue with the desktop IDE? I'll note it down and look into it.
  • M5stickC Touch Sensing
    8k Views
    X
    Thank you!
  • UIFlow Remote cannot get data
    4k Views
    m5stackM
    thank you feedback. we will test this function.
  • Check In and Out System for school project
    5k Views
    m5stackM
    why you put the timer start in the loop? I do not particularly clearly the functions implemented by the program
  • M5StickC ToF Hat UIFlow example missing?
    12
    13k Views
    M5StickC and ToF Hat work great with firmware UIFlow 1.6.5.1 :) [image: uLQQGC.png]
  • UIFlow initiates AtomMatrix not correct when switching
    8
    12k Views
    world101W
    Looks like you got it working, but what I was referring to with the Execute block was adding the full command like this to see if it would override the first. [image: 1604065459161-screen-shot-2020-10-30-at-9.43.07-am-resized.png] In the Python tab it looks like the command duplicated. I don't have the AtomQR to test with, so I'm not sure if this works or not... [image: 1604066142567-screen-shot-2020-10-30-at-9.43.54-am-resized.png] However, I found another workaround without the Execute block. After loading the AtomicQR example flow, then switch from Atom-Lite to Atom-Matrix in the settings, it will indeed add rgb.set_screen([]) on the Python tab. This is the bug. If you just select one of the 25 LED squares in the UI editor to change it to white, then select the same square again to change it back to black. Check the Python tab again and it will now show rgb.set_screen([0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]) automatically. If you save that as a new program (ex: Atomic_QR-Matrix), the next time you load the file, it should have the Matrix as the hardware type and the correct rgb.set_screen command in the python tab.
  • Traceback on AtomMatrix when running example
    7
    7k Views
    m5stackM
    it is an old version program compatible problem. now we updated a new example. https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Core/Atom/Atom Matrix
  • Please provide UIFlow source code for ToF Hat
    4k Views
    m5stackM
    thank you feedback. now it fixed. you could use the new firmware version UIFlow 1.6.5.1
  • UIFlow on core 2
    9
    16k Views
    m5stackM
    MacOS users please put M5Burner App in the Application folder after the installation as shown in the figure below. [image: application.webp]
  • Prevent autosleep
    1 Votes
  • Prevent autosleep
  • DAC library in C convert to UIflow
    7k Views
    K
    @gaviota I know this unit. But I have a unit on the MCP4728 chip. There are python libraries available but I can't make a custom block. Can you?
  • Tvoc in UIflow
    5k Views
    R
    I'm interested too as I have this module. Have you found a way to use it? Regards, Eduardo
  • ERROR Invalid syntax (UIFlow 1.6.2) when trying to upload
    12
    22k Views
    A
    @m5stack FW1.6.4 and editor 1.0.12 totally broke my program, still can't upload but then again, why would I need to, it doesn't even run anymore, the python code gets screwed up. I don't get to make an app anymore, all I do is running into stuff that doesn't work. It seems to me M5stack is suffering from what I call the "Yamaha disease" : keep spitting out new hardware without fixing the mediocre stuff they released before. Well I for one am not jumping on that train anymore , I refrain from buying any more new stuff a la core2 and whatnot before the existing stuff gets fixed. (which I expect now, will never happen)
  • SORACOM 3G Module support in UI Flow
    uiflow
    10
    23k Views
    T
    @ciniml could you please explain the new Cellular UIfow blocks and give an example on how to use them in sequential order? I also saw the Soracom m5f example and I wonder if the flow can start as it did, checking the SIMstate without setting any UART communication in advance? If I start running just the first two instructions, shall I expect returned True as you? I'm chasing who can help me in using the COMx.LTE module with those UIflow methods Thanks
  • Help with interrupt
    3k Views
  • Cellular UIFlow blocks
    5k Views
    T
    More specifically I need to know if the Arduino code downloadable here can be alternatively implemented by means of the UIFlow blocks belonging to the Cellular palette and, if so, I'd be interested to know how. Thanks
  • Trying to get stick V working
    3k Views
  • UIFlow MQTT topic single level wildcard '+'
    5k Views
    T
    Thanks a lot, I rescued this limitation (which makes the mqtt client not compliant to the standard) by setting properly the server side
  • issue with lego+ aka DC Motor module
    5k Views
    SkinkS
    @hetzer said in issue with lego+ aka DC Motor module: I cant make lego+ aka dc motor module. It gives error" moduel' object has no attribute Legoboard. Can anyone assist? I guess you are using the wrong commands in UIFlow 1.6.3. The (DC motor (Lego+) module) and its control commands UIFlow 1.6.3[image: 1600225081648-dc-modul-resized.jpg] [image: 1600225132010-dc-motor-modul-resized.jpg] The (BaseX module) and its control commands UIFlow 1.6.3 [image: 1600225213172-xbase-modul-resized.jpg] [image: 1600225273120-xbase-resized.jpg] In the description of the (DC motor (Lego+) module) the picture may be confusing because there are the commands M1 etc., but these commands are for the BaseX module and not the (DC motor (Lego+) module) !
