    2. SOFTWARE
    3. UIFlow
    4. Bug Report
    • Most Posts
    Bug Report
    • ** [IMPORTANT] Read before posting a report! **
      • Zontex
      Votes
      2140
      Views
    • R
      Only "Font_Default" on the Core2?
      • RIDDSprojects
      Votes
      26
      Views
    • Labels show up as blank white rectangles when running program
      • greenleaf
      Votes
      73
      Views
      As you can see I'm not doing anything especially exotic or weird here:
    • S
      ESPNow with M5StickC Plus in UIFlow v1.10.2
      • singtaro
      Votes
      190
      Views
      S
      Thank you for answering! The firmware of my M5StickC Plus is v1.9.1, which seems to be outdated. When I wrote v1.10.2 with the presented M5 burner, it worked properly. It was rudimentary. Thank you very much.
    • Azure IoT Speaker play_local path variable does not work
      • greenleaf
      Votes
      120
      Views
    • Azure IoT Speaker play_cloud command broken
      • greenleaf
      Votes
      101
      Views
    • H
      UiFlow 1.10.2 Core2 white screen indefinitely
      • HWTaro9
      Votes
      120
      Views
    • Y
      M5Burner couldn't burn
      • yu_with_a_mission
      Votes
      354
      Views
      Have you installed the device drivers Xcode (from the App Store) and Python 3?
    • M5Burner does not work in MacOX 12.3.
      uiflow m5 burner • • oyouji
      18
      Votes
      18
      4751
      Views
      @yu_with_a_mission said in M5Burner does not work in MacOX 12.3.: @yopita I tried you way and get another error, "File"/Applications/M5Burner.app/Contents/Resources/packages/tools/serial/tools/list_ports_osx.py", line 32, in <module> kIOMasterPortDefault = ctypes.c_void_p.in_dll(iokit, "kIOMasterPortDefault") ValueError: dlsym(RTLD_DEFAULT, kIOMasterPortDefault): symbol not found ================= Burn Failed =================" How can I solve? System: MacOS Monterey 12.4 Device: M5StickCPlus There is an Issue Montery. Have you installed Xcode from the App Store? Have you instilled the latest Python 3 from the python site? Have you installed the drivers? Have you set the PATH variable correctly? Have you copied the M5Burner V3 to the Applications folder? Have you erased the controller first before writing the correct firmware?
    • J
      "Flash Card" UI Flow Demo fails on Core 2
      • jvn314
      Votes
      243
      Views
      J
      Web UI Flow V1.4.5 (latest) and Firmware v1.9.8-core2 (latest)
    • B
      new m5stack: Failed to write to target RAM (result was 01070000)
      • burton
      22
      0
      Votes
      22
      14998
      Views
      @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
    • S
      Font size 10 Not functioning on V1.98
      • SE
      Votes
      403
      Views
      S
      This is on a Core2
    • H
      Problem "in list function"
      • hwkit
      Votes
      292
      Views
    • C
      uiflow online unable to open recently saved files (Core 1.9.5)
      • cortado
      11
      Votes
      11
      2308
      Views
      J
      @ajb2k3 said in uiflow online unable to open recently saved files (Core 1.9.5): M5Pi Thank you, ajb2k3. So if I need to include a custom block, it cant be used in M5flow? The strange thing is that the custom block works - I just cant upload the UI flow program after it was saved. I need a simple way to get a 1-wire temperature sensor (DS18B20) connected and later implement a simple PID temperature control. Any suggestions of how i interface with DS18B20 using M5flow? I really hope I can keep working with M5flow as this makes programming much easier for kids.
    • S
      UIFlow places WiFi connection code in the wrong place
      • Slartibartfast
      0
      Votes
      3761
      Views
      W
      @slartibartfast Hate to bump an old topic but this is a problem for me still. The "Original Network Function" blocks place the calls to the wlan class correctly but they don't actually work. This is UIFlow 1.9.6 now. It makes it impossible to use the program except in the coverage area of the SSID hard coded into the program. For a workaround, you can manually relocate the call to doConnect inside the loop or function where you want it. You can save that, and when you upload the program to the device it seems to send the modified python.
    • UIFLow 1.9.5 ImportError: no module named 'comx'
      • diwdi_io
      Votes
      845
      Views
      @ajb2k3 Thanks for the information but I did this over the M5Burner. My AtomDTU is up to date. With the 1.9.4 it works like expected.
    • O
      M5Burn cannot set option to USB-mode for local UIFlow-IDE
      • oklab-ka
      0
      Votes
      2579
      Views
      offline mode does not work because the desktop side is out of date.
    • S
      UIFlow + StepMotor Driver M039
      • starcrouz
      Votes
      911
      Views
      S
      A little update : UIFlow has been updated. The state and direction are not usable the same way : . That change broke our program (it's a pitty). Now you can use variables, you need to make 'ifs' because direction is now forward/reverse et state is now pause/resume. At the same time, bugs are still there : you cannot command a single motor, even if you use "set single motor X state resume", it will start the 3 motors at the same time. You must use the workaround I talked about in my previous post : pwm.
    • A
      M5Burner: Firmware list is not displayed
      firmware m5burner • • akira_teratera
      Votes
      626
      Views
    • can not download UI FLOW IDE for MacOS
      uiflow uiflow-ide mac • • oyouji
      0
      Votes
      1213
      Views
      Just now, I have confirmed it to be downloadable. Thanks!
    Move Topic
