Subcategories
    125 Topics
    A
  • 211 Topics
    robskiR
    @GiovanniCaenazzo disconnect M5Dial press and hold boot button at the back ofM5Dial - in the middle of Stamp Controller - it is very gentle switch connect M5Dial to USB M5Burner should detect com port in boot mode
  • 11 Topics
    A
  • uiflow 1.1 mqtt
    Moved
    11k Views
    ajb2k3A
    @watson Yes, I need to understand MQTT to work out part of my book but I'm just not understanding it.
  • Neopixel Experiments in uiflow
    Moved
    9
    13k Views
    ajb2k3A
    @watson said in Neopixel Experiments in uiflow: @ajb2k3 How about your neopixel breathing project? That's the base layer code but it only lights the Pixels in a predefined sequence. Need to find a way to randomize the sequence instead of hard-coding the pattern.
  • UIFlow : standalone
    Moved
    6k Views
    H
    sorry, currently it is not possible because of security issues.
  • M5Stick's mini and UIFlow
    Moved
    10
    19k Views
    H
    hello, lcd.print() is not support in m5stick uiflow
  • python back to blocks not working
    Moved
    13k Views
    m5-docsM
    @360fashion Hello, it's normal. UIFlow likes Blockly(designed by Google) and MakeCode(designed by MicroBit and Microsoft) You need to save it
  • What does this mean?
    Moved
    8k Views
    H
    hello,if wifi connect fail will appear thoese msg, Btn retry mean you can press btn to retry connect wifi, long press btn mean press long time(2 sec) can go to wifi setup, change wifi connect
