@watson Thanks- can you use arduino-ide?
@watson Thank you.
Do I choose CAMERA_MODEL_WROVER_KIT?
You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
// Select camera model //#define CAMERA_MODEL_WROVER_KIT #define CAMERA_A_MODEL_M5STACK_PSRAM //#define CAMERA_MODEL_AI_THINKER
@watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
@gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62#elif defined(CAMERA_A_MODEL_M5STACK_PSRAM) #define PWDN_GPIO_NUM -1 #define RESET_GPIO_NUM 15 #define XCLK_GPIO_NUM 27 #define SIOD_GPIO_NUM 25 #define SIOC_GPIO_NUM 23 #define Y9_GPIO_NUM 19 #define Y8_GPIO_NUM 36 #define Y7_GPIO_NUM 18 #define Y6_GPIO_NUM 39 #define Y5_GPIO_NUM 5 #define Y4_GPIO_NUM 34 #define Y3_GPIO_NUM 35 #define Y2_GPIO_NUM 32 #define VSYNC_GPIO_NUM 22 #define HREF_GPIO_NUM 26 #define PCLK_GPIO_NUM 21
Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
@gachapo said in [Solved] M5 Burner Firmware Option Update:
No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
Something I have failed to do several times now.
can also program with arduino ide
@watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
Compiles and uploaded the sketch.
Nothing! - Camera doesn't even turn on.
Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
@gachapo
I just registered for you :D
Here what is solved my problem (Y2_GPIO_NUM):#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
#define SIOC_GPIO_NUM 23#define Y9_GPIO_NUM 19
#define Y2_GPIO_NUM 17 //32
@oyye said in [Solved] M5 Burner Firmware Option Update:
@gachapo
#define PCLK_GPIO_NUM 21Welcome to the forum!
@oyye Thank-you,
I did as you stated with only change from the Arduino Examples being;
This has made no change - Camera still does not come on.
Just to be absolutely clear - this is the camera a have
![0_1556260445735_20190426_073011.jpg](Uploading 100%)
Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
@gachapo Do you own M5Camera A model and B model? or ESP32CAM?
@m5-docs I own an M5 OV2640 ESP32PSRAM Camera
@gachapo But, M5Camera A model and B model both own PSRAM chip.
Please take a picture for your camera board.
