    69 Posts 7 Posters 439.2k Views 1 Watching
    • m5-docsM Offline
      m5-docs
      @GACHAPO @ajb2k3 Thanks your support
      M5Stack documentation URL
      https://docs.m5stack.com
      • G Offline
        GACHAPO @m5-docs
        @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
        • m5-docsM Offline
          m5-docs @GACHAPO
          @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
          https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
          #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
          #define PWDN_GPIO_NUM     -1
          #define RESET_GPIO_NUM    15
          #define XCLK_GPIO_NUM     27
          #define SIOD_GPIO_NUM     25
          #define SIOC_GPIO_NUM     23
          #define Y9_GPIO_NUM       19
          #define Y8_GPIO_NUM       36
          #define Y7_GPIO_NUM       18
          #define Y6_GPIO_NUM       39
          #define Y5_GPIO_NUM        5
          #define Y4_GPIO_NUM       34
          #define Y3_GPIO_NUM       35
          #define Y2_GPIO_NUM       32
          #define VSYNC_GPIO_NUM    22
          #define HREF_GPIO_NUM     26
          #define PCLK_GPIO_NUM     21
          • G Offline
            GACHAPO
            Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
            • m5-docsM Offline
              m5-docs @GACHAPO
              @gachapo
              • G Offline
                GACHAPO
                Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
                  ajb2k3 @GACHAPO
                  @gachapo said in [Solved] M5 Burner Firmware Option Update:
                  No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
                  Something I have failed to do several times now.
                  • m5-docsM Offline
                    m5-docs
                    can also program with arduino ide
                    • G Offline
                      GACHAPO @m5-docs
                      @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
                      Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
                      I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
                      Compiles and uploaded the sketch.
                      Nothing! - Camera doesn't even turn on.
                      Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
                      • O Offline
                        Oyye @GACHAPO
                        @gachapo
                        I just registered for you :D
                        Here what is solved my problem (Y2_GPIO_NUM):
                        #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
                        #define Y2_GPIO_NUM 17 //32
                        ajb2k3A G 2 Replies Last reply Reply Quote 0
                          ajb2k3 @Oyye
                          @oyye said in [Solved] M5 Burner Firmware Option Update:
                          @gachapo
                          Welcome to the forum!
                          • G Offline
                            GACHAPO @Oyye
                            @oyye Thank-you,
                            I did as you stated with only change from the Arduino Examples being;
                            This has made no change - Camera still does not come on.
                            Just to be absolutely clear - this is the camera a have
                            ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
                            • G Offline
                              GACHAPO
                              Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                @gachapo Do you own M5Camera A model and B model? or ESP32CAM?
                                • G Offline
                                  GACHAPO @m5-docs
                                  @m5-docs I own an M5 OV2640 ESP32PSRAM Camera
                                  • m5-docsM Offline
                                    m5-docs @GACHAPO
                                    @gachapo But, M5Camera A model and B model both own PSRAM chip.
                                    Please take a picture for your camera board.
                                    https://docs.m5stack.com/#/en/unit/m5camera
                                    • G Offline
                                      GACHAPO
                                      Mine is B
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        Hello @gachapo
                                        You can download the following example code for your board.
                                        That's the configuration for B Model.
                                        #define SIOD_GPIO_NUM     22
                                        #define VSYNC_GPIO_NUM    25
                                        • G Offline
                                          GACHAPO
                                          I feel like I'm walking through mud!!!!!!!!!!!!!!!!!!
                                          I have downloaded the software as suggested.
                                          I amended the SSID and Password to enable access to my network
                                          I compile and uploaded the software
                                          Surprisingly a new access point LidarBot + MAC address appeared, contrary to me setting my own network credentials.
                                          I connected to this AP and put the password in as stated in the code.
                                          browsed to 192.168.4.1
                                          Software appeared, but no camera image and NO ABILITY TO GET ON MY NETWORK, WHICH IS WHAT I HAVE REQUESTED AGAIN AND AGAIN.
                                          It doesn't have to be this hard.........................................................please make it simple!
                                          How do I get this camera on my network with Arduino IDE????
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            @gachapo What log information did your device print?
