    69 Posts 7 Posters 431.7k Views 1 Watching
    • m5-docsM Offline
      m5-docs
      Hello @GACHAPO @ajb2k3,
      Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
      M5Stack documentation URL
      https://docs.m5stack.com
      • G Offline
        GACHAPO @m5-docs
        @watson Thanks for coming back to me.
        I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
        • m5-docsM Offline
          m5-docs @GACHAPO
          @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
          Here's the doc for it.
          • G Offline
            GACHAPO
            That's great thank you - works.
            Is there any documentation about how to assign your own IP address to the camera please?
            • m5-docsM Offline
              m5-docs @GACHAPO
              @gachapo Do you mean this doc?
              https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
              • G Offline
                GACHAPO
                I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                  ajb2k3 @GACHAPO
                  @gachapo you need to recompile the code is ST mode and upload to cameea
                  • G Offline
                    GACHAPO @ajb2k3
                    @ajb2k3 Thanks - Is there any documentation you can point me to please?
                      ajb2k3 @GACHAPO
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo At main.c file
                        • G Offline
                          GACHAPO
                          Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                          • m5-docsM Offline
                            m5-docs @GACHAPO
                            @gachapo
                            Download the firmware of ESP32CAM
                            • G Offline
                              GACHAPO
                              ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                                ajb2k3 @m5-docs
                                @watson I can't use the M5burner of the Stick C as it it coming up as
                                Port: "dev/cu.serial-6D52F9B441
                                instead of the expected
                                Port: "dev/cu.SLAB_USBtoUART
                                • m5-docsM Offline
                                  m5-docs @ajb2k3
                                  @ajb2k3 Are you working with Mac OS?
                                    ajb2k3 @m5-docs
                                    @watson
                                    Yes, but is only the StickC that is giving the strange port ID.
                                    All others report normal port.
                                    • m5-docsM Offline
                                      m5-docs @GACHAPO
                                      @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                                        salty_good
                                        I understood this problem.
                                        We need to fix M5Burner for mac.
                                          ajb2k3 @salty_good
                                          @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                                          Can you add drop down box to select port?
                                          ポートを選択するためのドロップダウンボックスを追加できますか?
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
