    69 Posts 7 Posters 439.2k Views 1 Watching
      ajb2k3 @GACHAPO
      @gachapo you need to recompile the code is ST mode and upload to cameea
      • G Offline
        GACHAPO @ajb2k3
        @ajb2k3 Thanks - Is there any documentation you can point me to please?
          ajb2k3 @GACHAPO
          • m5-docsM Offline
            m5-docs @GACHAPO
            @gachapo At main.c file
            M5Stack documentation URL
            https://docs.m5stack.com
            • G Offline
              GACHAPO
              Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
              • m5-docsM Offline
                m5-docs @GACHAPO
                @gachapo
                Download the firmware of ESP32CAM
                • G Offline
                  GACHAPO
                  ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                    ajb2k3 @m5-docs
                    @watson I can't use the M5burner of the Stick C as it it coming up as
                    Port: "dev/cu.serial-6D52F9B441
                    instead of the expected
                    Port: "dev/cu.SLAB_USBtoUART
                    • m5-docsM Offline
                      m5-docs @ajb2k3
                      @ajb2k3 Are you working with Mac OS?
                        ajb2k3 @m5-docs
                        @watson
                        Yes, but is only the StickC that is giving the strange port ID.
                        All others report normal port.
                        • m5-docsM Offline
                          m5-docs @GACHAPO
                          @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                            salty_good
                            I understood this problem.
                            We need to fix M5Burner for mac.
                              ajb2k3 @salty_good
                              @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                              Can you add drop down box to select port?
                              ポートを選択するためのドロップダウンボックスを追加できますか?
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                  salty_good @ajb2k3
                                  @ajb2k3 Off course yes,
                                  and Baudrate also needs to be selectable.
                                  • G Offline
                                    GACHAPO @m5-docs
                                    @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                                    • m5-docsM Offline
                                      m5-docs @GACHAPO
                                      Hello @gachapo It's best to use esp-idf.
                                      • G Offline
                                        GACHAPO @m5-docs
                                        @watson Thanks- can you use arduino-ide?
                                        • m5-docsM Offline
                                          m5-docs @GACHAPO
                                          Hello @gachapo,
                                          Yes, Color recognition arduino program may help you.
                                          Here's the code:
                                          https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
                                          • G Offline
                                            GACHAPO @m5-docs
                                            @watson Thank you.
                                            Do I choose CAMERA_MODEL_WROVER_KIT?
