    M5Stack - Simple Applications Menu + some APPs
    PROJECTS
    10
    40
    214.2k
    • T
      TomSuch @JJ
      @jimit OK, I'm going to check it out ..
      • T
        TomSuch @JJ
        @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
        https://github.com/tomsuch/M5Stack-SAM
        JJJ 1 Reply Last reply Reply Quote 0
        • JJJ
          JJ @TomSuch
          @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
          T 1 Reply Last reply Reply Quote 0
          • T
            TomSuch @JJ
            @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
            https://github.com/tomsuch/M5Stack-SAM/
            JJJ 1 Reply Last reply Reply Quote 1
            • JJJ
              JJ @TomSuch
              @tomsuch
              Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
              T 1 Reply Last reply Reply Quote 1
              • T
                TomSuch @JJ
                @jimit No problem Jim. Regards....
                • K
                  kaotiklabs
                  Would be awesome to have a generic menu system so you could focus only on core development.
                  I have tried to use yours for my app but had no time to fully understand it.
                  Could you write a little doc explaining how can we use it in our apps?
                  • SunWukongS
                    SunWukong @TomSuch
                    @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                    The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                    • T
                      TomSuch
                      @sunwukong Hi, Thank you for the subject. I will look at it.
                      For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                      http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                      • T
                        TomSuch @kaotiklabs
                        @kaotiklabs Hi, Thank you for the subject. I will look at it.
                        • T
                          TomSuch @m5stack
                          @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                          • reaper7R
                            reaper7
                            Accu meter app (MAX17043 module soldered inside Battery Module)
                            MY GITHUB: https://github.com/reaper7/
                            T JJJ 2 Replies Last reply Reply Quote 3
                            • T
                              TomSuch @reaper7
                              @reaper7 Good work, thank you ...
                              • JJJ
                                JJ @reaper7
                                @reaper7
                                Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                                • T
                                  TomSuch
                                  A new version of the M5StackSAM library
                                  https://github.com/tomsuch/M5StackSAM
                                  Added features to easily create and navigate the list.
                                  (APPLICATIONS -> LIST DEMO)
                                  Added support for the FACES QWERTY keyboard.
                                  (APPLICATIONS -> FACES GET STRING)
                                  • JJJ
                                    JJ @TomSuch
                                    @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                                    • S
                                      sheepDog
                                      Hello,
                                      what version/type of wire.h do you use?
                                      I got this error at "Wire.requestFrom(0x08,1,true);":
                                      In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                                       from sketch/M5StackSAM.h:1,
                                                       from sketch/M5StackSAM.cpp:1:
                                      /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                                      /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                                           uint8_t requestFrom(int, int, int);
                                      /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                                           size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                                      Can anyone help me?
                                      • W
                                        wschnell @SunWukong
                                        @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
                                        • W
                                          wschnell @SunWukong
                                          found it - it's a Seeed Studio Wrapper
                                          • T
                                            TheAlphaGhost
                                            Hi Guys,
                                            ihm new with M5Stack. I have a MCore2 and try compile this in visual code with plattform.io.
                                            How i must use the code in Plattform.io ? If i compile the code, the device showing black screen.
                                            Can anyone help me ?
