    M5Stack - Simple Applications Menu + some APPs
    PROJECTS
    10
    40
    233.0k
    • T
      TomSuch @JJ
      @jimit Hi, good work. But I did not find the code on your git ...
      • JJJ
        JJ @TomSuch
        @tomsuch
        Oops... sorry bout that. Have added them now....
        • T
          TomSuch @JJ
          @jimit OK, I'm going to check it out ..
          • T
            TomSuch @JJ
            @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
            https://github.com/tomsuch/M5Stack-SAM
            • JJJ
              JJ @TomSuch
              @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
              • T
                TomSuch @JJ
                @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                https://github.com/tomsuch/M5Stack-SAM/
                • JJJ
                  JJ @TomSuch
                  @tomsuch
                  Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                  • T
                    TomSuch @JJ
                    @jimit No problem Jim. Regards....
                    • K
                      kaotiklabs
                      Would be awesome to have a generic menu system so you could focus only on core development.
                      I have tried to use yours for my app but had no time to fully understand it.
                      Could you write a little doc explaining how can we use it in our apps?
                      • SunWukongS
                        SunWukong @TomSuch
                        @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                        The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                        • T
                          TomSuch
                          @sunwukong Hi, Thank you for the subject. I will look at it.
                          For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                          http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                          • T
                            TomSuch @kaotiklabs
                            @kaotiklabs Hi, Thank you for the subject. I will look at it.
                            • T
                              TomSuch @m5stack
                              @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                              • reaper7R
                                reaper7
                                Accu meter app (MAX17043 module soldered inside Battery Module)
                                T JJJ 2 Replies Last reply Reply Quote 3
                                • T
                                  TomSuch @reaper7
                                  @reaper7 Good work, thank you ...
                                  • JJJ
                                    JJ @reaper7
                                    @reaper7
                                    Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                                    • T
                                      TomSuch
                                      A new version of the M5StackSAM library
                                      https://github.com/tomsuch/M5StackSAM
                                      Added features to easily create and navigate the list.
                                      (APPLICATIONS -> LIST DEMO)
                                      Added support for the FACES QWERTY keyboard.
                                      (APPLICATIONS -> FACES GET STRING)
                                      • JJJ
                                        JJ @TomSuch
                                        @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                                          sheepDog
                                          what version/type of wire.h do you use?
                                          I got this error at "Wire.requestFrom(0x08,1,true);":
                                          In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                                           from sketch/M5StackSAM.h:1,
                                                           from sketch/M5StackSAM.cpp:1:
                                          /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                                          /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                                               uint8_t requestFrom(int, int, int);
                                          /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                                               size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                                          Can anyone help me?
                                          • W
                                            wschnell @SunWukong
                                            @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
