    M5Stack - Simple Applications Menu + some APPs
    PROJECTS
    10
    40
    240.6k
    • T
      TomSuch @Kryten
      @kryten Please specify the error. Arduino version. Take PrintScreen.
      Do you have installed M5.libraries ? ESP32 libraries ?
      • reaper7R
        reaper7
        @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
        APP - GY-512
        very nice system!
        APP - GY-512 works also with built-in MPU9250 :)
        Can You modify TIM MEASUREMENT APP?
        S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
        • T
          TomSuch @reaper7
          @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
          • JJJ
            JJ
            T 2 Replies Last reply Reply Quote 0
            • T
              TomSuch @JJ
              @jimit Hi, good work. But I did not find the code on your git ...
              • JJJ
                JJ @TomSuch
                @tomsuch
                Oops... sorry bout that. Have added them now....
                • T
                  TomSuch @JJ
                  @jimit OK, I'm going to check it out ..
                  • T
                    TomSuch @JJ
                    @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                    https://github.com/tomsuch/M5Stack-SAM
                    • JJJ
                      JJ @TomSuch
                      @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                      • T
                        TomSuch @JJ
                        @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                        https://github.com/tomsuch/M5Stack-SAM/
                        • JJJ
                          JJ @TomSuch
                          @tomsuch
                          Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                          • T
                            TomSuch @JJ
                            @jimit No problem Jim. Regards....
                            • K
                              kaotiklabs
                              Would be awesome to have a generic menu system so you could focus only on core development.
                              I have tried to use yours for my app but had no time to fully understand it.
                              Could you write a little doc explaining how can we use it in our apps?
                              • SunWukongS
                                SunWukong @TomSuch
                                @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                                The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                                • T
                                  TomSuch
                                  @sunwukong Hi, Thank you for the subject. I will look at it.
                                  For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                  http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                                  • T
                                    TomSuch @kaotiklabs
                                    @kaotiklabs Hi, Thank you for the subject. I will look at it.
                                    • T
                                      TomSuch @m5stack
                                      @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                      • reaper7R
                                        reaper7
                                        Accu meter app (MAX17043 module soldered inside Battery Module)
                                        T JJJ 2 Replies Last reply Reply Quote 3
                                        • T
                                          TomSuch @reaper7
                                          @reaper7 Good work, thank you ...
                                          • JJJ
                                            JJ @reaper7
                                            @reaper7
                                            Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
