    M5Stack - Simple Applications Menu + some APPs
    PROJECTS
    10
    40
    231.9k
    • reaper7R
      reaper7
      @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
      APP - GY-512
      very nice system!
      APP - GY-512 works also with built-in MPU9250 :)
      Can You modify TIM MEASUREMENT APP?
      S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
      • T
        TomSuch @reaper7
        @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
        • JJJ
          JJ
          T 2 Replies Last reply Reply Quote 0
          • T
            TomSuch @JJ
            @jimit Hi, good work. But I did not find the code on your git ...
            • JJJ
              JJ @TomSuch
              @tomsuch
              Oops... sorry bout that. Have added them now....
              • T
                TomSuch @JJ
                @jimit OK, I'm going to check it out ..
                • T
                  TomSuch @JJ
                  @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                  https://github.com/tomsuch/M5Stack-SAM
                  • JJJ
                    JJ @TomSuch
                    @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                    • T
                      TomSuch @JJ
                      @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                      https://github.com/tomsuch/M5Stack-SAM/
                      • JJJ
                        JJ @TomSuch
                        @tomsuch
                        Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
                        • T
                          TomSuch @JJ
                          @jimit No problem Jim. Regards....
                          • K
                            kaotiklabs
                            Would be awesome to have a generic menu system so you could focus only on core development.
                            I have tried to use yours for my app but had no time to fully understand it.
                            Could you write a little doc explaining how can we use it in our apps?
                            • SunWukongS
                              SunWukong @TomSuch
                              @tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
                              The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
                              • T
                                TomSuch
                                @sunwukong Hi, Thank you for the subject. I will look at it.
                                For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
                                • T
                                  TomSuch @kaotiklabs
                                  @kaotiklabs Hi, Thank you for the subject. I will look at it.
                                  • T
                                    TomSuch @m5stack
                                    @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
                                    • reaper7R
                                      reaper7
                                      Accu meter app (MAX17043 module soldered inside Battery Module)
                                      T JJJ 2 Replies Last reply Reply Quote 3
                                      • T
                                        TomSuch @reaper7
                                        @reaper7 Good work, thank you ...
                                        • JJJ
                                          JJ @reaper7
                                          @reaper7
                                          Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
                                          • T
                                            TomSuch
                                            A new version of the M5StackSAM library
                                            https://github.com/tomsuch/M5StackSAM
                                            Added features to easily create and navigate the list.
                                            (APPLICATIONS -> LIST DEMO)
                                            Added support for the FACES QWERTY keyboard.
                                            (APPLICATIONS -> FACES GET STRING)
