    M5Stack - Simple Applications Menu + some APPs
    PROJECTS
    10
    40
    240.6k
    • T
      TomSuch @m5stack
      @m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
      http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
      • reaper7R
        reaper7
        Accu meter app (MAX17043 module soldered inside Battery Module)
        T JJJ 2 Replies Last reply Reply Quote 3
        • T
          TomSuch @reaper7
          @reaper7 Good work, thank you ...
          • JJJ
            JJ @reaper7
            @reaper7
            Yes - nice mod & addition to the menu system Reaper7 ! Ordered the module already. Thanks.
            • T
              TomSuch
              A new version of the M5StackSAM library
              https://github.com/tomsuch/M5StackSAM
              Added features to easily create and navigate the list.
              (APPLICATIONS -> LIST DEMO)
              Added support for the FACES QWERTY keyboard.
              (APPLICATIONS -> FACES GET STRING)
              • JJJ
                JJ @TomSuch
                @tomsuch Excellent thanks Tom.... look forward to trying it esp. with the new Faces keyboard support. Will try later tonight....
                  sheepDog
                  what version/type of wire.h do you use?
                  I got this error at "Wire.requestFrom(0x08,1,true);":
                  In file included from /Users/.../Documents/Arduino/libraries/M5Stack/src/M5Stack.h:92:0,
                                   from sketch/M5StackSAM.h:1,
                                   from sketch/M5StackSAM.cpp:1:
                  /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h: In member function 'void M5SAM::keyboardEnable()':
                  /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:66:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
                       uint8_t requestFrom(int, int, int);
                  /Users/.../Documents/Arduino/hardware/espressif/esp32/libraries/Wire/src/Wire.h:61:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
                       size_t requestFrom(uint8_t address, size_t size, bool sendStop);
                  Can anyone help me?
                  • W
                    wschnell @SunWukong
                    @sunwukong Hey, where did you get the enclosure for the grove sensor? - I've been looking for something like this.
                    • W
                      wschnell @SunWukong
                      found it - it's a Seeed Studio Wrapper
                      • T
                        TheAlphaGhost
                        Hi Guys,
                        ihm new with M5Stack. I have a MCore2 and try compile this in visual code with plattform.io.
                        How i must use the code in Plattform.io ? If i compile the code, the device showing black screen.
                        Can anyone help me ?
