    ESP NOW send not working in 1.6.1
    Bug Report
    13.0k
    • A
      ardo
      Not sure if this belongs here (only bug related area i can find)
      ESP NOWis not working properly in firmware 1.6.1
      I tested this on m5stickC and core basic, it only works on firmware 1.4.5, not on later versions
      in fact its the sending that gives an "interface error", receiving seems to work fine
      (I'm using UIFlow btw)
      • IAMLIUBOI
        IAMLIUBO
        Hi @ardo ,
        I just test it with StickC and Core basic,It work well in firmware V1.6.1.Can you show your "blocks" with us?
        • A
          ardo @IAMLIUBO
          @iamliubo
          Hi, this program works perfectly in 1.4.5, here's what gives in 1.6.1:
          If I take out the "send" block, it works, it receives msgs
          • IAMLIUBOI
            IAMLIUBO
            Hi @ardo ,
            Can you share your m5f file with us?
            • A
              ardo @IAMLIUBO
              @iamliubo
              Sure, but how would I upload an m5f ?
              • IAMLIUBOI
                IAMLIUBO @ardo
                Hi @ardo ,
                You can send it to us the official support email.
                Official support email addr: support@m5stack.com
                • A
                  ardo @IAMLIUBO
                  @iamliubo
                  Ah, ok; file sent.
                  thanks for investigating this.
                  • m5stackM
                    m5stack @ardo
                    @ardo thank you feedback this bug. we will fix this bug as soon as possible ,
                    you could follow this operation let the code runing.
                    use online UIflow to open the program file , and runing
                    or
                    offline version need add wifiCfg.wlan_sta.active(True) in the python code. (next to wifiCfg.wlan_ap.active(True))
                    • A
                      ardo @m5stack
                      @m5stack
                      And thank you for looking into this and the quick workaround
                      (It also seems to work when I put that line in an "Execute" block)
                      However...
                      While you are fixing this, you might also have to take a look at the "After send message" block, now that I've got the send working again, it looks to me this block does not return a value.(it did in 1.4.5) I can again provide an m5f file if you'd need it.
                      • m5stackM
                        m5stack @ardo
                        @ardo ok thank you again.. we will fix these bug in next version. have nice day.
