    M5Stack - AutoCAD Drawings
    15 Posts 2 Posters 37.6k Views 2 Watching
      KenTinker
      I'll have to set a GitHub page up. Will advise once I get that done.
      • JJJ Offline
        JJ @KenTinker
        @kentinker Yes good idea.... I'd like to add them to mine too if thats cool..
          KenTinker @JJ
          @jimit Fine with me. Part of why I tried to post them here. I get a lot of help from various boards and like to provide a bit back when I can
          • JJJ Offline
            JJ @KenTinker
            @kentinker Thanks! I agree. Collaboration makes a huge difference...
              KenTinker @JJ
              @jimit Ok - see if I did the GitHub thing right :) The files are here: https://github.com/KenTinker/M5Stack---ACAD-Files
              • JJJ Offline
                JJ @KenTinker
                @kentinker Fast work ! Thanks.
                I had to enter the location manually but I found the files and extracted them successfully.
                The link didn't work.....
                If you have time/can be bothered, I think the link will work if you change the location name by removing at least one of the dashes (-). Doesn't seem to cope with three. Two seemed OK.
                https://github.com/kentinker/m5stack/---ACAD-Files
                  KenTinker @JJ
                  @jimit Hmmm. I blame IE. That was how it copied from the explorer bar :)
                  https://github.com/KenTinker/M5Stack--ACAD-Files
                  JJJ K 2 Replies Last reply Reply Quote 0
                  • JJJ Offline
                    JJ @KenTinker
                    @kentinker Sorry - to clarify my not very clear comments - I meant I think the link will work if you go into github and change the name from: https://github.com/KenTinker/M5Stack---ACAD-Files - to - https://github.com/KenTinker/M5Stack--ACAD-Files (with one less dash).
                    Doesn't worry me - they can be accessed manually... just in case you want to....
                      KenTinker @KenTinker
                      @kentinker That doesn't work either. I shouldn't have cursed IE. Looks like the issue may have been me adding in a '-' when I setup the GitHub repository. Couldn't figure out how to rename it, so I made a new one. Knock on wood this link works:
                      https://github.com/KenTinker/M5Stack-Prototype-ACAD-Files
                        KenTinker @JJ
                        @jimit I figured that part out but not quite how to rename.
                          KenTinker @JJ
                          @jimit hope I didn't mess up your link. First time working with setting up my own things on GitHub. The revised link seems to work fine from here now:
                          • JJJ Offline
                            JJ @KenTinker
                            @kentinker Excellent. Probs a good idea to have a nice working link for the future. No worries - didn't mess me up. Good luck with the github - so far so good. Its very useful and powerful once you get into it.
                            I will add your files up to my github later on.... thanks again.
