<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack - AutoCAD Drawings]]></title><description><![CDATA[<p dir="auto">All - I pulled down the prototype board drawings that were contained in the M5 Harware Master. They appear to be in Altium Designer format which is a bit of a PIA for me to use. After downloading the Altium Viewer, I spent a little time setting up ACAD drawings for the board which I can import into other PCB design tools, etc. The attached ZIP file contains DWG and DXF versions in metric and inch formats for anyone who may be able to make use of them. [0_1520779800053_M5Stack Proto - ACAD.zip](Uploading 100%)</p>
]]></description><link>https://community.m5stack.com/topic/134/m5stack-autocad-drawings</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:07:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/134.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Mar 2018 14:50:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Mon, 12 Mar 2018 00:04:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a> Excellent. Probs a good idea to have a nice working link for the future. No worries - didn't mess me up. Good luck with the github - so far so good. Its very useful and powerful once you get into it.</p>
<p dir="auto">I will add your files up to my github later on....  thanks again.</p>
]]></description><link>https://community.m5stack.com/post/578</link><guid isPermaLink="true">https://community.m5stack.com/post/578</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Mon, 12 Mar 2018 00:04:00 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:54:31 GMT]]></title><description><![CDATA[<p dir="auto">@jimit hope I didn't mess up your link. First time working with setting up my own things on GitHub. The revised link seems to work fine from here now:</p>
<p dir="auto"><a href="https://github.com/KenTinker/M5Stack-Prototype-ACAD-Files" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/KenTinker/M5Stack-Prototype-ACAD-Files</a></p>
]]></description><link>https://community.m5stack.com/post/577</link><guid isPermaLink="true">https://community.m5stack.com/post/577</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:54:31 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:49:23 GMT]]></title><description><![CDATA[<p dir="auto">@jimit I figured that part out but not quite how to rename.</p>
]]></description><link>https://community.m5stack.com/post/576</link><guid isPermaLink="true">https://community.m5stack.com/post/576</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:48:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a> That doesn't work either. I shouldn't have cursed IE. Looks like the issue may have been me adding in a '-' when I setup the GitHub repository. Couldn't figure out how to rename it, so I made a new one. Knock on wood this link works:<br />
]]></description><link>https://community.m5stack.com/post/575</link><guid isPermaLink="true">https://community.m5stack.com/post/575</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:48:31 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:44:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a> Sorry - to clarify my not very clear comments - I meant I think the link will work if you go into github and change the name from:  <a href="https://github.com/KenTinker/M5Stack---ACAD-Files" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/KenTinker/M5Stack---ACAD-Files</a>   -  to  -  <a href="https://github.com/KenTinker/M5Stack--ACAD-Files" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/KenTinker/M5Stack--ACAD-Files</a>  (with one less dash).</p>
<p dir="auto">Doesn't worry me - they can be accessed manually... just in case you want to....</p>
]]></description><link>https://community.m5stack.com/post/574</link><guid isPermaLink="true">https://community.m5stack.com/post/574</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:44:43 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:41:05 GMT]]></title><description><![CDATA[<p dir="auto">@jimit Hmmm. I blame IE. That was how it copied from the explorer bar :)</p>
<p dir="auto"><a href="https://github.com/KenTinker/M5Stack--ACAD-Files" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/KenTinker/M5Stack--ACAD-Files</a></p>
]]></description><link>https://community.m5stack.com/post/573</link><guid isPermaLink="true">https://community.m5stack.com/post/573</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:41:05 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:39:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a>   Fast work !  Thanks.</p>
<p dir="auto">I had to enter the location manually but I found the files and extracted them successfully.</p>
<p dir="auto">The link didn't work.....</p>
<p dir="auto">If you have time/can be bothered, I think the link will work if you change the location name by removing at least one of the dashes (-). Doesn't seem to cope with three. Two seemed OK.</p>
<p dir="auto"><a href="https://github.com/kentinker/m5stack/---ACAD-Files" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kentinker/m5stack/---ACAD-Files</a></p>
]]></description><link>https://community.m5stack.com/post/572</link><guid isPermaLink="true">https://community.m5stack.com/post/572</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:39:11 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:27:44 GMT]]></title><description><![CDATA[<p dir="auto">@jimit Ok - see if I did the GitHub thing right :) The files are here: <a href="https://github.com/KenTinker/M5Stack---ACAD-Files" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/KenTinker/M5Stack---ACAD-Files</a></p>
]]></description><link>https://community.m5stack.com/post/570</link><guid isPermaLink="true">https://community.m5stack.com/post/570</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:27:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:25:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a>  Thanks! I agree. Collaboration makes a huge difference...</p>
]]></description><link>https://community.m5stack.com/post/569</link><guid isPermaLink="true">https://community.m5stack.com/post/569</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:25:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:16:06 GMT]]></title><description><![CDATA[<p dir="auto">@jimit Fine with me. Part of why I tried to post them here. I get a lot of help from various boards and like to provide a bit back when I can</p>
]]></description><link>https://community.m5stack.com/post/568</link><guid isPermaLink="true">https://community.m5stack.com/post/568</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:16:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:05:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a> Yes good idea.... I'd like to add them to mine too if thats cool..</p>
]]></description><link>https://community.m5stack.com/post/564</link><guid isPermaLink="true">https://community.m5stack.com/post/564</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:05:27 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 23:02:55 GMT]]></title><description><![CDATA[<p dir="auto">I'll have to set a GitHub page up. Will advise once I get that done.</p>
]]></description><link>https://community.m5stack.com/post/563</link><guid isPermaLink="true">https://community.m5stack.com/post/563</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 23:02:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 21:04:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a> Hi Ken,</p>
<p dir="auto">Yes it seems to only allow photo/picture uploads.....  Got a github page? I'm sure others would be keen to share your files.</p>
]]></description><link>https://community.m5stack.com/post/554</link><guid isPermaLink="true">https://community.m5stack.com/post/554</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 11 Mar 2018 21:04:47 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack - AutoCAD Drawings on Sun, 11 Mar 2018 14:53:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentinker" aria-label="Profile: kentinker">@<bdi>kentinker</bdi></a> Hmm - maybe attached :) It looks like I may not have the account privileges to upload.... any suggestions?</p>
]]></description><link>https://community.m5stack.com/post/553</link><guid isPermaLink="true">https://community.m5stack.com/post/553</guid><dc:creator><![CDATA[KenTinker]]></dc:creator><pubDate>Sun, 11 Mar 2018 14:53:43 GMT</pubDate></item></channel></rss>
