    Serial connection problem and connection to server failed
    SOFTWARE
    • R
      RIDDSprojects
      Dear all,
      After unpacking the M5STAMP PICO (D4), I immediately installed the latest firmware. I then soldered it directly to a PCB. However, the blue LED remains lit during startup.
      The current meter on my lab power supply repeatedly jumps back and forth (approximately 50~100mA): apparently, it is repeatedly trying to connect. The Wi-Fi mode (yellow) is working properly: I can connect to configure the Wi-Fi key.
      I unsoldered GPIO pins G0 through G3 to reinstall the firmware. This doesn't work. "A serial connection cannot be established."
      This problem resembles https://forum.m5stack.com/topic/7606/m5stamp-pico-solid-blue-light
      However, soldering seems to be the problem here
      (of course, I checked for bad connections or short circuits to pins or to components near the pads).
      What could I try to fix the problem? Where should I look?
      Thank you in advance.
      ATOM LITE | ATOM MATRIX | CORE | CORE2 | STAMP-PICO | CORE.INK | PAPER V1.1
      RESEARCH | INNOVATION | DEVELOPMENT | DESIGN | SUSTAINABILITY
      and electronics
      • robskiR
        robski @RIDDSprojects
        @RIDDSprojects any pictures of it being soldered to pcb?
