<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Serial connection problem and connection to server failed]]></title><description><![CDATA[<p dir="auto">Dear all,</p>
<p dir="auto">After unpacking the M5STAMP PICO (D4), I immediately installed the latest firmware. I then soldered it directly to a PCB. However, the blue LED remains lit during startup.</p>
<p dir="auto">The current meter on my lab power supply repeatedly jumps back and forth (approximately 50~100mA): apparently, it is repeatedly trying to connect. The Wi-Fi mode (yellow) is working properly: I can connect to configure the Wi-Fi key.</p>
<p dir="auto">I unsoldered GPIO pins G0 through G3 to reinstall the firmware. This doesn't work. "A serial connection cannot be established."</p>
<p dir="auto">This problem resembles <a href="https://forum.m5stack.com/topic/7606/m5stamp-pico-solid-blue-light" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/7606/m5stamp-pico-solid-blue-light</a><br />
However, soldering seems to be the problem here<br />
(of course, I checked for bad connections or short circuits to pins or to components near the pads).</p>
<p dir="auto">What could I try to fix the problem? Where should I look?</p>
<p dir="auto">Thank you in advance.</p>
]]></description><link>https://community.m5stack.com/topic/8007/serial-connection-problem-and-connection-to-server-failed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 21:31:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8007.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Jan 2026 20:12:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Sun, 01 Feb 2026 18:48:10 GMT]]></title><description><![CDATA[<p dir="auto">Serial and server connection issues can be tricky — been there! Sometimes it’s just a port config or baud mismatch. Hope you find the root cause soon!</p>
]]></description><link>https://community.m5stack.com/post/30552</link><guid isPermaLink="true">https://community.m5stack.com/post/30552</guid><dc:creator><![CDATA[PitDuran]]></dc:creator><pubDate>Sun, 01 Feb 2026 18:48:10 GMT</pubDate></item><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Sat, 17 Jan 2026 20:18:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bschwahn" aria-label="Profile: bschwahn">@<bdi>bschwahn</bdi></a><br />
Thanks for your reply.</p>
<p dir="auto">The current consumption fluctuates between 50 and 100mA and is due to the Wi-Fi connection (this is what all modules searching for a Wi-Fi connection or exchanging data over Wi-Fi do, so that's not surprising).</p>
<p dir="auto">I've re-measured all the connections. I haven't desoldered the module yet.</p>
<p dir="auto">The humidity was approximately 60%. The module was moved between different rooms after the initial firmware update, but before soldering. An ESD issue could have occurred there.</p>
<p dir="auto">Thank you for your support.</p>
]]></description><link>https://community.m5stack.com/post/30482</link><guid isPermaLink="true">https://community.m5stack.com/post/30482</guid><dc:creator><![CDATA[RIDDSprojects]]></dc:creator><pubDate>Sat, 17 Jan 2026 20:18:19 GMT</pubDate></item><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Sat, 17 Jan 2026 20:05:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/riddsprojects" aria-label="Profile: RIDDSprojects">@<bdi>RIDDSprojects</bdi></a></p>
<p dir="auto">Greetings,</p>
<p dir="auto">What is the current draw of the PICO when not soldered to anything (yet doing the same tasks)? Are you sure there are not any issues with the PCB?</p>
<p dir="auto">I am really in the dark here yet anytime soldering is involved there are concerns.</p>
<p dir="auto">The problem might be heat related as electronic parts can be sensitive and can only survive a certain level of heat in a given amount of time. As stated ESD can also be an issue especially in dry areas where the relative humidity is less than 30 percent.</p>
<p dir="auto">Hope you resolve your issues-Brian.</p>
]]></description><link>https://community.m5stack.com/post/30480</link><guid isPermaLink="true">https://community.m5stack.com/post/30480</guid><dc:creator><![CDATA[bschwahn]]></dc:creator><pubDate>Sat, 17 Jan 2026 20:05:08 GMT</pubDate></item><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Fri, 16 Jan 2026 15:44:56 GMT]]></title><description><![CDATA[<p dir="auto">I'm going to completely desolder the Pico and then test it separately. I suspect the problem persists because nothing has been changed on the PCB. I'll post an update of my findings here.</p>
<p dir="auto">Perhaps it's an ESD-related issue. This is the second time a similar problem has occurred with the Pico, while it hasn't happened with other controllers in a enclosure.</p>
]]></description><link>https://community.m5stack.com/post/30470</link><guid isPermaLink="true">https://community.m5stack.com/post/30470</guid><dc:creator><![CDATA[RIDDSprojects]]></dc:creator><pubDate>Fri, 16 Jan 2026 15:44:56 GMT</pubDate></item><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Thu, 15 Jan 2026 15:04:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/riddsprojects" aria-label="Profile: RIDDSprojects">@<bdi>RIDDSprojects</bdi></a> just wonder if controller will show same issue out of your pcb</p>
]]></description><link>https://community.m5stack.com/post/30466</link><guid isPermaLink="true">https://community.m5stack.com/post/30466</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Thu, 15 Jan 2026 15:04:43 GMT</pubDate></item><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Wed, 14 Jan 2026 19:07:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi Robski,</p>
<p dir="auto">Unfortunately, I can't show a photo due to (future) intellectual property regarding the PCB to which the module is soldered.<br />
Thank you for your input. I'll try to explain the situation in as much detail as possible.<br />
It was soldered manually, but professionally, and then tested for connection and short-circuiting.</p>
<p dir="auto">When connecting the USB-TTL Downloader, external hardware was disconnected from IO pins G0, G1, and G3 by desoldering solder pads elsewhere on the PCB. EN and 3V3 are not connected.</p>
<p dir="auto">Do you have any specific questions about the PCB?</p>
]]></description><link>https://community.m5stack.com/post/30458</link><guid isPermaLink="true">https://community.m5stack.com/post/30458</guid><dc:creator><![CDATA[RIDDSprojects]]></dc:creator><pubDate>Wed, 14 Jan 2026 19:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to Serial connection problem and connection to server failed on Mon, 12 Jan 2026 13:36:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/riddsprojects" aria-label="Profile: RIDDSprojects">@<bdi>RIDDSprojects</bdi></a> any pictures of it being soldered to pcb?</p>
]]></description><link>https://community.m5stack.com/post/30440</link><guid isPermaLink="true">https://community.m5stack.com/post/30440</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 12 Jan 2026 13:36:19 GMT</pubDate></item></channel></rss>
