    2. RIDDSprojects
    R
    • Continue chat with RIDDSprojects
    • Start new chat with RIDDSprojects
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    RIDDSprojects
    @RIDDSprojects
    Reputation
    8
    662
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    Location NL
    RIDDSprojects Follow
    Posts made by RIDDSprojects
    • RE: round to one decimal in UI flow
      Under Text you will find this option, at the very bottom: Reduce ... to x decimal places. It has been tucked away a bit, but works very well.
      posted in UIFlow
      R
      RIDDSprojects
    • RE: Object has no attribute - Error
      Dear Felix,
      You helped me a lot! I had already looked several times for a firmware update, but it got stuck at v1.9.8. Thanks for your tip to use M5Burner Version 3 - I used M5Burner Version 2.5.1 myself. Confusing, but now clear! With, now v1.11.0, it works well!
      Thank you! Also for your very quick response.
      posted in UIFlow
      R
      RIDDSprojects
    • Object has no attribute - Error
      It's very simple. The steps I do:
      1. Add unit (+) in UIFlow
      2. Add DIGI-CLOCK, default setting (Port A)
        2b. OK
      3. Open tap 'Units (1)' (under 'Hardwares') > Digi Clock
      4. Get block 'digi_clock_0 init 12c address (0x30).
      5. Run
      Error: File "<string>", line 8, in <module>
      AttributeError: 'module' object has no attribute 'DIGI_CLOCK'
      1. Add other blocks; does not matter
      2. Grab another controller; makes no difference (also error).
      Controlling directly with I2C is possible:
      (remove unit)
      Tap 'Hardwares', I2C Master:
      Block 1: i2c0 Master portA freq 400000
      Block 2: i2c0 Set slave addr 0x30
      Block 3: i2c0 Write reg 0x4 one byte 0xFF
      Display result: 8. (and no error!)
      Who can help me or has an addition?
      posted in UIFlow
      R
      RIDDSprojects
    • Only "Font_Default" on the Core2?
      Hello,
      I recently got the Core2, but run into limitations in UIFlow (current version V1.10.3). The font in the "Grapfic blocks" is limited to "Font_Default" when using the Core2. The labels can be set to other fonts. I prefer not to use labels because that limits me to using 1 screen.
      Another solution is to put the generated code in an "Execute-block":
      label0 = M5Label('Montserrat 10 t/m 48', x=0, y=35, color=0xffffff, font=FONT_MONT_26, parent=None)
      but that is more of a temporary clumsy solution.
      Can you as developers pay attention to this?
      Thanks in advance!
      posted in Bug Report
      R
      RIDDSprojects
    • RE: Different Pages on M5Stack Core
      In this example two pages with the same layout, but in practice this is of course not necessary:
      As an extra example from practice (one of my first programs in UIFlow) with two different screens:
      posted in UIFlow
      R
      RIDDSprojects
    • RE: Set Atom Matrix block duplication bug - color reverts to white
      Hello,
      It helps to select a different color first. Then you can still make copies. An annoying detour indeed.
      posted in UIFlow
      R
      RIDDSprojects
    • RE: How to use Remote + Switch?
      Hi,
      It's also my experience that it doesn't always work if you have multiple switches, input fields, buttons, etc. I see "Switch 4" with you, so I assume that there are multiple switches.
      The solution I used in one of the projects with multiple input fields is to apply custom variables. Then suddenly it works! Hopefully that will help you too.
      posted in UIFlow
      R
      RIDDSprojects
      @rotor
      This is quite simple on the Core: With the "Graphic" blocks it is easy to create graphical pages with "labels". Unfortunately, this is not so easy on the Core2 and functions are missing.
      You do not use labels, but the following 3 blocks: [Lcd.clear]; [Font:...]; [Lcd.print "Label1" x: 0 y: 0 Color...]; [Lcd.print "..." x: 0 y: 20 Color...]; etc. You can first design them graphically by dragging labels onto the screen to determine the position, to then copy the screen with the graphic blocks, test whether all text appears on top of each other, and then edit the dragged labels. remove.
      Use the "Functions" ("dosomething") blocks to create a page (Page1, Page2, etc). For example, by making "Setup" followed by a block "Page3", only page 3 will be visible, without using labels and you still have all the flexibility.
      I hope that's how I answered your question. This is how I create multiple pages.
      posted in UIFlow
      R
      RIDDSprojects
