@britontour If m5burner registered the device into uiflow, and it shows having a MAC and Token value (partially masked out), then it should be re-paired properly.
I'm unsure why your device can not connect to the server to report itself online.
I've just verified the process still works (I don't have a core s3 but used a cardputer which is stamp s3 based)I did just discover a bug in the 2.0.2 "develop" screen. It may be cardputer specific, but it incorrectly displays "private" in both modes. It's just a display bug though, it isn't effecting my connection
@dissy I see "PRIVATE" on the Develop screen of the S3, even though I configured it as Public. This is what I see in uiflow2 GUI when I click on the device button.
What server connection does it need? I may need to get IP or ports whitelisted at my office.
My only way to connect to my S3 is USB cable. I click on the run button, and a web terminal window appears. I select the COM port and press connect. Press the play button at the top and I see my python code downloading. at the end , I get an error message (see below). If the line number is referring to my python code, I don't see what the problem is.
Line 68: rectOrigin = None
Line 102: if lengthTargetCycles >= 3:
Line 103: txtTargetCycles3.setText(str(listTargetCycles[2]))===
File "<stdin>", line 68
SyntaxError: invalid syntaxOccasionally, the line number changes.
File "<stdin>", line 102
@britontour said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
Before it connects it will read "private" in yellow, and show "user account" as "none"
After it successfully connects this will change and should show "public" in green and your email address in "user account"What server connection does it need? I may need to get IP or ports whitelisted at my office.
https (port 443) to host uiflow2.m5stack.com
My IT guy helped me work out the issue with the connection to the server. Access to ntp.aliyun.com was blocked. I changed it to our local gateway ntp server and I can connect to the S3 successfully over wifi!! Onto the next bug!!
A new Bug!
What does this mean? It doesn't change from 0%
My issue with Sync is also fixed. It was another issue with aliyun.com access restriction by my company's IT dept
OK, so I am finally making progress with my design, and I see so many features missing that really should be available for a modern development environment. There is no option for design reuse, code sharing, custom functions, etc. If I want to use some example code, I have to recreate each step in my project.
Moving from uiflow1 to uiflow2, I had to rebuild every block of my design. If I find something useful in an example project, I can't just copy/paste from one window to the other, again, I have to manually rebuild what I want in my project.
Is there a roadmap for planned features to be added to uiflow2?
@britontour Maybe it is time for you to expand into Arduino IDE where all your complaints are answered.
-Cheers
@iamliubo Why only DAC hat is available with m5staick? No more hats?
@kris said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
Because it take time to write and develop the code so that it doesn’t cause breakers in other code
Hi. I'm missing the 4-Relay Unit in the list of possible devices. Can you please add that back, as it exists in uiflow 1?
Hello @zendes
maybe my example (PlayZone: M5Dial_4RelayUnit_UIFlow2.0.1) can help out until the native 4-relay unit gets added in UIFlow2.
Note: you might need to modify the I2C pins for SCL and SCK dependent on the core you are using.
These are current products for sale in the M5 store. Wasn't the NCIR-2 introduced over two years ago? I think there would have been ample time to integrate them into the latest UIFlow.
Hello @wmatkins
re: NCIR hat : I think it should work by adding the NCIR unit but with a custom I2C setting, e.g. SCL=26 and SDA=0.
Note: I do not have the NCIR hat or unit so I cannot test this myself.
Hello @sorphin
I can confirm that in M5Dial UIFlow2.0.3 firmware the blocks for the built-in RFID reader are not working and throw an error. However, as a workaround, I used the blocks of a virtual RFID unit (and modified I2C SCL and SDA pins) to successfully read RFID cards with the internal RFID reader. See PlayZone M5Dial_RFID_UIFlow2.0.3 example.
@felmue Thanks for confirming as well Felix. I did find that I could make it work in a round about way as well (using rfid.RFID (no parenthesis)).. but one shouldn't have to do that :/
I have 3 issues currently:
This is very fast (less than a minute).When I use UiFlow 2.0's web interface to upload my program (~20KB) via USB in the web terminal, however, It is very very slow (~2-3 minutes).
The issue also happens when I upload a file from the web terminal.
When I upload a file or program, it results in an empty (0 Bytes) file! (most of the time), I burned the old Alpha-29 version of UIFlow 2 on my device using M5Burner, and this problem is fixed -
Half of the time, when I run the program, the colors are inverted (instead of RGB, it's BGR, literally)
I would like to use the touchscreen on the M5Dial. But the block M5.Touch.getCount() does not work in a while loop! It only works in the main loop. So the touchscreen is hardly usable in Micropython. I have not been able to realize the waiting for a touch.
