    Librerías ESP32 vs Arduino
    Foro español
    25.7k
    • P
      PiriX
      Yes, I did. M5Stack-ESP32
      • O
        oscillator @PiriX
        @pirix said in Librerías ESP32 vs Arduino:
        Strange. Can you post the whole output of your compilation? Maybe there is some earlier error.
        What OS are you running?
        • P
          PiriX
          That's what I trying to run
          https://github.com/frittna/Crypto_Coin_Ticker
          I'm on a MacBook Pro 16" Intel i9, macOS Big Sur
          • P
            PiriX @oscillator
            @oscillator Arduino: 1.8.16 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
            Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
            Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
            In file included from /Users/pirix/Documents/Arduino/Crypto_Coin_Ticker-master/Crypto_Coin_Ticker/Crypto_Coin_Ticker.ino:20:0:
            /Users/pirix/Documents/Arduino/libraries/Timezone/src/Timezone.h:16:66: fatal error: TimeLib.h: No such file or directory
            Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/SD
            compilation terminated.
            Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
            exit status 1
            • O
              oscillator
              Do you have the Timezone library installed?
              In the docs for the Timezone library it says:
              "The Timezone library is designed to work in conjunction with the Arduino Time library, which must also be installed on your system."
              There is also a note in the beginning of the code:
              // !!! Library versions should match to mentioned below !!!
              // !!!!!!!!!!!! Otherwise code won't work !!!!!!!!!!!!!!!!!
              Do you have the right version of the libraries installed?
              • P
                PiriX @oscillator
                @oscillator Exactly what they recommend
                • O
                  oscillator
                  You seem to have prepared everything that they want...
                  Also, I am running on GNU/Linux so...sorry, can't help you...
                  • P
                    PiriX @oscillator
                    @oscillator Thank you so much for your interest!
                    • O
                      oscillator
                      Hmmm, found this: https://forum.arduino.cc/t/timelib-h-no-such-file-or-directory/413110/4
                      I know they talk about Windows, and you run OSX, but maybe this applies to you too?
                      • P
                        PiriX @oscillator
                        @oscillator Thank you!
