<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Librerías ESP32 vs Arduino]]></title><description><![CDATA[<p dir="auto">Buenas a todos...<br />
Estoy intentado correr un programa, pero me encuentro con el mensaje</p>
<p dir="auto">Multiple libraries were found for "WiFi.h"<br />
Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi<br />
Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi<br />
Multiple libraries were found for "SD.h"<br />
Error compiling for board M5Stack-Core-ESP32.</p>
<p dir="auto">Cómo solventar este problema de librerías entre Arduino y ESP32?</p>
]]></description><link>https://community.m5stack.com/topic/3592/librerías-esp32-vs-arduino</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 10:18:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3592.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Sep 2021 16:17:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 22:12:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oscillator" aria-label="Profile: oscillator">@<bdi>oscillator</bdi></a> Thank you!</p>
]]></description><link>https://community.m5stack.com/post/14956</link><guid isPermaLink="true">https://community.m5stack.com/post/14956</guid><dc:creator><![CDATA[PiriX]]></dc:creator><pubDate>Thu, 23 Sep 2021 22:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 21:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pirix" aria-label="Profile: pirix">@<bdi>pirix</bdi></a> said in <a href="/post/14945">Librerías ESP32 vs Arduino</a>:</p>
<p dir="auto">Arduino/libraries/Timezone/src/Timezone.h:16:66: fatal error: TimeLib.h: No such file or directory</p>
<p dir="auto">Hmmm, found this: <a href="https://forum.arduino.cc/t/timelib-h-no-such-file-or-directory/413110/4" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.arduino.cc/t/timelib-h-no-such-file-or-directory/413110/4</a></p>
<p dir="auto">I know they talk about Windows, and you run OSX, but maybe this applies to you too?</p>
]]></description><link>https://community.m5stack.com/post/14954</link><guid isPermaLink="true">https://community.m5stack.com/post/14954</guid><dc:creator><![CDATA[oscillator]]></dc:creator><pubDate>Thu, 23 Sep 2021 21:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 21:12:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oscillator" aria-label="Profile: oscillator">@<bdi>oscillator</bdi></a> Thank you so much for your interest!</p>
]]></description><link>https://community.m5stack.com/post/14953</link><guid isPermaLink="true">https://community.m5stack.com/post/14953</guid><dc:creator><![CDATA[PiriX]]></dc:creator><pubDate>Thu, 23 Sep 2021 21:12:02 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 20:51:26 GMT]]></title><description><![CDATA[<p dir="auto">You seem to have prepared everything that they want...</p>
<p dir="auto">Also, I am running on GNU/Linux so...sorry, can't help you...</p>
]]></description><link>https://community.m5stack.com/post/14952</link><guid isPermaLink="true">https://community.m5stack.com/post/14952</guid><dc:creator><![CDATA[oscillator]]></dc:creator><pubDate>Thu, 23 Sep 2021 20:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 20:32:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oscillator" aria-label="Profile: oscillator">@<bdi>oscillator</bdi></a> Exactly what they recommend</p>
]]></description><link>https://community.m5stack.com/post/14951</link><guid isPermaLink="true">https://community.m5stack.com/post/14951</guid><dc:creator><![CDATA[PiriX]]></dc:creator><pubDate>Thu, 23 Sep 2021 20:32:33 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 17:17:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pirix" aria-label="Profile: pirix">@<bdi>pirix</bdi></a> said in <a href="/post/14945">Librerías ESP32 vs Arduino</a>:</p>
<p dir="auto">Documents/Arduino/libraries/Timezone</p>
<p dir="auto">Do you have the Timezone library installed?</p>
<p dir="auto">In the docs for the Timezone library it says:<br />
"The Timezone library is designed to work in conjunction with the Arduino Time library, which must also be installed on your system."</p>
<p dir="auto">There is also a note in the beginning of the code:</p>
<p dir="auto">// !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!<br />
// !!! Library versions should match to mentioned below !!!<br />
// !!!!!!!!!!!! Otherwise code won't work !!!!!!!!!!!!!!!!!</p>
<p dir="auto">Do you have the right version of the libraries installed?</p>
]]></description><link>https://community.m5stack.com/post/14946</link><guid isPermaLink="true">https://community.m5stack.com/post/14946</guid><dc:creator><![CDATA[oscillator]]></dc:creator><pubDate>Thu, 23 Sep 2021 17:17:03 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 13:28:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oscillator" aria-label="Profile: oscillator">@<bdi>oscillator</bdi></a> Arduino: 1.8.16 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"</p>
In file included from /Users/pirix/Documents/Arduino/Crypto_Coin_Ticker-master/Crypto_Coin_Ticker/Crypto_Coin_Ticker.ino:20:0:<br />
/Users/pirix/Documents/Arduino/libraries/Timezone/src/Timezone.h:16:66: fatal error: TimeLib.h: No such file or directory<br />
Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/SD<br />
compilation terminated.<br />
Not used: /Applications/Arduino.app/Contents/Java/libraries/SD<br />
exit status 1<br />
<p dir="auto">This report would have more information with<br />
"Show verbose output during compilation"<br />
option enabled in File -&gt; Preferences.</p>
]]></description><link>https://community.m5stack.com/post/14945</link><guid isPermaLink="true">https://community.m5stack.com/post/14945</guid><dc:creator><![CDATA[PiriX]]></dc:creator><pubDate>Thu, 23 Sep 2021 13:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 09:52:39 GMT]]></title><description><![CDATA[<p dir="auto">That's what I trying to run</p>
<p dir="auto"><a href="https://github.com/frittna/Crypto_Coin_Ticker" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/frittna/Crypto_Coin_Ticker</a></p>
<p dir="auto">I'm on a MacBook Pro 16" Intel i9, macOS Big Sur</p>
]]></description><link>https://community.m5stack.com/post/14943</link><guid isPermaLink="true">https://community.m5stack.com/post/14943</guid><dc:creator><![CDATA[PiriX]]></dc:creator><pubDate>Thu, 23 Sep 2021 09:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 09:36:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pirix" aria-label="Profile: pirix">@<bdi>pirix</bdi></a> said in <a href="/post/14941">Librerías ESP32 vs Arduino</a>:</p>
<p dir="auto">Yes, I did. M5Stack-ESP32</p>
<p dir="auto">Strange. Can you post the whole output of your compilation? Maybe there is some earlier error.</p>
<p dir="auto">What OS are you running?</p>
]]></description><link>https://community.m5stack.com/post/14942</link><guid isPermaLink="true">https://community.m5stack.com/post/14942</guid><dc:creator><![CDATA[oscillator]]></dc:creator><pubDate>Thu, 23 Sep 2021 09:36:16 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 09:14:21 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I did. M5Stack-ESP32</p>
]]></description><link>https://community.m5stack.com/post/14941</link><guid isPermaLink="true">https://community.m5stack.com/post/14941</guid><dc:creator><![CDATA[PiriX]]></dc:creator><pubDate>Thu, 23 Sep 2021 09:14:21 GMT</pubDate></item><item><title><![CDATA[Reply to Librerías ESP32 vs Arduino on Thu, 23 Sep 2021 07:56:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pirix" aria-label="Profile: pirix">@<bdi>pirix</bdi></a> said in <a href="/post/14929">Librerías ESP32 vs Arduino</a>:</p>
<p dir="auto">When I compile for the Core2 I also get <em>warnings</em>, eg:</p>
<p dir="auto">Multiple libraries were found for "SD.h"<br />
Used: /home/staffan/.arduino15/packages/m5stack/hardware/esp32/1.0.9/libraries/SD<br />
Not used: /home/staffan/Arduino/libraries/SD</p>
<p dir="auto">but that doesn't stop my compilation.</p>
<p dir="auto">Have you selected the right board in the Tools menu?</p>
]]></description><link>https://community.m5stack.com/post/14940</link><guid isPermaLink="true">https://community.m5stack.com/post/14940</guid><dc:creator><![CDATA[oscillator]]></dc:creator><pubDate>Thu, 23 Sep 2021 07:56:48 GMT</pubDate></item></channel></rss>
