    M5ez 2.0: testers wanted...
    M5EZ
    7
    26
    126.5k
      moelski
      Hi Rop,
      just waiting for my M5 so I can't help out.
      But can you tell a little bit about the new features?
      regards
      Dominik
      • B
        bobolink
        @Rop
        Sure
        • R
          r_255
          Hey Rop,
          Nice you are making progress!
          I would like to see if i can move the slider in a negative way, not sure if i am much of a help with my skills.
          But thats all up to you. Happy with all your efforts anyway.
          Meanwhile i spend some time on doing what is more familiar to me.
          Hi @ Moelski
          • RopR
            Rop
            Thanks... Looks great... Let me think about a few small changes if I may, and then I'd like to use that...But first let's get 2.0 out the door...
            • R
              r_255
              Its all yours..... Adjustments is no problem, its all vector gfx.
              You can drop me a line at my hotmail.com account for the changes, just add my forum nick in front.
              Cheers
              • J
                jeanvdr
                Hi Rop,
                I've got my m5stack since one week to make a remote interface for my home-automation system. So, I was naturally driven to m5ez, which was only laking multitasking (for mqtt) and a timeout LCD backlight management which like I read is part of v2.0. I'll be glad to be able to test it if possible. Thanks.
                Jean
                • R
                  r_255
                  This is spinning in my head... next to this dual core thingy. I guess this is what you get when i get frustrated from programming... lol
                  • J
                    jeanvdr @r_255
                    @r_255 Very, very nice !!! Can we get your theme and icons somewhere ? Thanks
                    • R
                      r_255
                      Everything you see is just work in progress and hand drawn in vectors( sunday morning frustrations ). Ill make a bundle with stuffbut sofar its just all in one screen and vector. Would be great to make it a community effort and make it into a demo file that is included with M5ez.
                      Not sure about what the end point is, can we scale sliders. re position them.
                      I did re use most of my old gfx for a ipad interface
                      and that is downloadable here
                      http://files.domoticaforum.eu/index.php?cam=/Graphics
                      • P
                        prickle
                        Hi guys, new user here. Tried M5ez installing from Manage Libraries, went to compile M5ez-demo, got the following error.
                        Arduino: 1.8.7 (Windows 7), TD: 1.44, Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                        C:\Users\prickle\Documents\Quadcopter\Arduino\libraries\M5ez\src/M5ez.h:28:49: fatal error: ezTime.h: No such file or directory
                        compilation terminated.
                        • B
                          bobolink @prickle
                          @prickle
                          You have to load @Rop’s ezTime Arduino library.
                          Instructions are actually in the upgrade notes but I didn’t read those either.
                          • P
                            prickle
                            I totally missed that link, cheers!
                            • R
                              r_255
                              Happy with v2.0
                              The slider works fine now !
                              While looking into your code to find the brightness slider i realized you did a shit load of work in a short period ... Amazing!
                              Big thank you!
                              Also made one based on the image menu and let the slider jump in steps of 20 and simply change the image
                              Still having a hard time with the programming, but slowly i am getting some where.
                              • RopR
                                Rop @r_255
                                @r_255 I would not go that route and write code that draws the image. And I would use the M5ez buttons on the display. If you want multiple sliders (for RGBW etc), you will end up wanting the long/short press functions to switch sliders and operate the sliders without too many presses. Your images have made me think about how to make things more generic and configurable...
                                • R
                                  r_255
                                  Hey Rop,
                                  I agree, and what you see is just a image from my design program. To get a estimate on how it looks in total on the m5. In the working model i use your header and buttons.
                                  i did just adjust the dark theme a bit and in between my image shows.
                                  Just playing with your work and see where the limits are. So far my programming is what limits me.
                                  Stuck on how to get the _brigtness value into my mqtt.
                                  Tried almost everything i can think of, did look into other code
                                  did look how variables are used, but this syntax is over my head. This publishes _Brightness as text but not as value.
                                  So close and still far away... It frustrates me over the past 2 days now.
                                  client.publish("domoticz/in", "{"command": "switchlight", "idx": 143, "switchcmd": "Set Level", "level": _brightness; }");
                                  It's just the basic skills i am missing, but in general i can understand what is happening.
                                  I agree on usability like in rgbw, but left or right and next option will set the previous isnt that hard. Less pushes makes things more use able, thats something that is my experience.
                                  a double push to go a level up/cancel might be more easy to understand for end users of the interface. While a enter or a level down is a single push of the middle button.
                                  Again, thanks for all your hard work ! and i do hope that the community contributes a bit more as in sharing experiences and code. So we dont expect 3.0 but there is still hope for v2.99 ;o)
                                  cheers
                                  Robin
                                  • RopR
                                    Rop @r_255
                                    @r_255 I don't know about this mqtt implementation, but in general, one would use _brightness.toInt() or _brightness.toFloat() to turn variable _brightness from a String into a number. Hope that helps.
                                    • R
                                      r_255 @Rop
                                      void menu_brightness_slider(){
                                        ezProgressBar bl ("Keukenlamp dimmer", "Set brightness", "left#off#ok#up#right#on");
                                                  while (true) {
                                                    String b = ez.buttons.poll();
                                                    if (b == "right" && brightness <= 90) brightness += 10;
                                                    if (!brightness) brightness = 100;
                                                    if (b == "left" && brightness > 11) brightness -= 10;
                                                    if (b == "left" && brightness < 11) brightness = 0.01;
                                                    bl.value((float)(brightness));
                                                    if (b == "ok") break;
                                                    if (b == "off")brightness = 0.01;
                                                    if (b == "on")brightness = 100;
                                                    if (b == "up") loop();
                                      // Prepare a JSON payload string
                                        String payload = "";
                                        payload += "{";
                                        payload += "\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\":";
                                        payload += brightness;
                                        payload += "}";
                                        // Send payload
                                        char attributes[100];
                                        payload.toCharArray( attributes, 100 );
                                        client.publish( "domoticz/in", attributes );
                                        Serial.println( attributes );
                                        menu_brightness_slider();
                                      This works ! :O)
                                      Now a long press set on or off or back to menu
                                      • R
                                        r_255
                                        Well slowly i am getting somewhere
                                        RopR 1 Reply Last reply Reply Quote 1
                                        • RopR
                                          Rop @r_255
                                          @r_255 Cool! :)
                                            Strang bug appears in this code
                                            #include <M5ez.h>
                                            #include <ezTime.h>
                                            #include "images.h"
                                            #define MAIN_DECLARED
                                            #include <themes/default.h>
                                            #include <themes/dark.h>
                                            ezt::setDebug(INFO);
                                            ez.begin();
                                            ezMenu images;
                                            images.imgBackground(TFT_BLACK);
                                            images.imgFromTop(40);
                                            images.imgCaptionColor(TFT_WHITE);
                                            images.addItem(sysinfo_jpg, "Photo Turntable", sysInfo);
                                            images.run();
                                            The title "Photo Turntable" get printed on the top and the bottom of the screen.
                                            (sorry no picture)
