@gachapo What log information did your device print?
		Posts made by m5-docs
    RE: [Solved] M5 Burner Firmware Option Updateposted in SOFTWARE
    RE: M5stack basic core battery power on issue (ip5306 strange power management)posted in Cores@arzaman Thanks. Your seriousness really touched me.
    RE: M5stack basic core battery power on issue (ip5306 strange power management)posted in Cores@arzaman The IP5306 which is iic version is customized. The best way for you is to ask saler for a replacement or ask our saler for a new core or iic version IP5306. Sorry for the inconvenience !
    RE: [Solved]How to use interruption processing in m5stackposted in CoresHello @tkb-koki, How about this example code?
    RE: M5stack basic core battery power on issue (ip5306 strange power management)posted in Cores@arzaman Really sorry about that. I do not clearly know your problem. "-if I disconnect USB using core bottom battery the core stays on and I can do reset with power on again
 -if I power off (double click) no change to power on again"
    RE: [Solved] M5 Burner Firmware Option Updateposted in SOFTWAREHello @gachapo You can download the following example code for your board. https://github.com/m5stack/Applications-cam That's the configuration for B Model. #define PWDN_GPIO_NUM -1 #define RESET_GPIO_NUM 15 #define XCLK_GPIO_NUM 27 #define SIOD_GPIO_NUM 22 #define SIOC_GPIO_NUM 23 #define Y9_GPIO_NUM 19 #define Y8_GPIO_NUM 36 #define Y7_GPIO_NUM 18 #define Y6_GPIO_NUM 39 #define Y5_GPIO_NUM 5 #define Y4_GPIO_NUM 34 #define Y3_GPIO_NUM 35 #define Y2_GPIO_NUM 32 #define VSYNC_GPIO_NUM 25 #define HREF_GPIO_NUM 26 #define PCLK_GPIO_NUM 21
    RE: [Solved]sleep mode on MircoPython?posted in MicropythonHello @akita11 Which version are you using? Here's mine.
    RE: M5stack basic core battery power on issue (ip5306 strange power management)posted in CoresHello @arzaman, In order to confirm that if the IP5306 is IIC version on all CORE you have. It's better to download the following testing code. https://github.com/m5stack/M5Stack/tree/master/examples/Advanced/I2C_Tester
    RE: [Solved]How to use interruption processing in m5stackposted in Cores@tkb-koki Do you means how to use BUTTON on M5Stack Core? If I am right, you can refer to the code blow. https://github.com/m5stack/M5Stack/tree/master/examples/Basics /* Name: button.ino Created: 2018/9/21 14:06:15 Author: sakabin */ #include <M5Stack.h> // The setup() function runs once each time the micro-controller starts void setup() { // init lcd, serial, but don't init sd card M5.begin(true, false, true); M5.Lcd.clear(BLACK); M5.Lcd.setTextColor(YELLOW); M5.Lcd.setTextSize(2); M5.Lcd.setCursor(65, 10); M5.Lcd.println("Button example"); M5.Lcd.setCursor(3, 35); M5.Lcd.println("Press button B for 700ms"); M5.Lcd.println("to clear screen."); M5.Lcd.setTextColor(RED); } // Add the main program code into the continuous loop() function void loop() { M5.update(); // if you want to use Releasefor("was released for"), use .wasReleasefor(int time) below if (M5.BtnA.wasReleased()) { M5.Lcd.print('A'); } else if (M5.BtnB.wasReleased()) { M5.Lcd.print('B'); } else if (M5.BtnC.wasReleased()) { M5.Lcd.print('C'); } else if (M5.BtnB.wasReleasefor(700)) { M5.Lcd.clear(BLACK); M5.Lcd.setCursor(0, 0); } } © 2019 GitHub, In
    RE: [Solved]sleep mode on MircoPython?posted in Micropython@akita11 Yes, as http://vcc-gnd.com told, use the following code import machine machine.lightsleep()will enter light sleep mode
    RE: [Solved] M5 Burner Firmware Option Updateposted in SOFTWARE@gachapo But, M5Camera A model and B model both own PSRAM chip. Please take a picture for your camera board.
    RE: [Solved] M5 Burner Firmware Option Updateposted in SOFTWARE@gachapo Do you own M5Camera A model and B model? or ESP32CAM?
    RE: [Solved]ESP32CAM 3.3vposted in Units@lurk_ Because there are SY8089, RT9182 chip between BAT pin and ESP32_VCC, in order to transfer high voltage to 3.3V. So you need a battery with higher voltage capacity.
    RE: [Solved]ESP32CAM 3.3vposted in Units@lurk_ Can not supply 3.3V. Please supply the voltage greater than 3.3V.
    RE: M5stack basic core battery power on issue (ip5306 strange power management)posted in Cores@arzaman How about BASIC Core boots only with Type-C USB cable without BASIC bottom?
    RE: [Solved]Schematics for M5StickC?posted in M5 Stick/StickC@hackbeere Sorry, We have never had its schematic
 This code is only for M5Camera A model.https://github.com/m5stack/Applications-cam If you want ESP32CAM to work, need to change this code for being Suitable for ESP32CAM.  Refer to what the README.md told
