    Don't know what to use
    FAQS
    5
    31
    60.6k
    • J
      jerome83136
      Hello,
      Thank you for your feedback.
      As I'm quite new on this kind of stuff (using pins to interact with an external component); I need some tips :)
      When I do this on UIFlow:
      I understand it activates the pin n°2 (LOW), when the "switch0" is activated. Am I right ?
      How can I identify the pin n°2 on my M5 Core basic with a base core bottom ?
      I think I need some documentation/tutorial to understand the correspondance between the pins used into UIFlow and the the pinmap on M5 Core Basic. Can I find this somewhere ?
      Thank you for your help
      Best regards
      • J
        jerome83136
        Hi,
        I finally got the relay working with M5 Core Basic !
        I think my mistake was to power the relay with 5v rather than 3.3v
        Here is my wiring:
        And here is the example UIFlow that works for me:
        Now I need to find a way to power the M5 Core Basic by using a DC 12V --> USB 5V connector and connect it to the DC 12V power supply I already use.
        Next step will be the hardest: understanding how PaHub works to interconnect the M5 Core Basic with:
        • RFID reader
        • M5 Scales kit
        • M5 Ultrasonic Distance Unit
        I will report progress here
        Thank you again for your help
        Best regards
        • J
          jerome83136
          Hi all,
          Another report here.
          Almost everything is ready.
          I'm quite sure the RFID2 reader won't do the job because of its short reading range; let's try and improve if required.
          I will certainly have to give this reader a try. (already ordered)
          1 question I had while testing: TOF and RFID2 seems to need Ports A or E. But Port E never worked (the unit is seen as "not connected" by the Core); forcing me to use a PaHub which is a pity because I have plenty of available ports with the ExtPort extension.
          Someone able to help me understanding why ? (If I could use port E; I could completely remove the PaHub)
          Here is the current setup:
          Last thing to do to complete the prototype: get a 12v --> 5V USB connector in order to power the M5 Core + 12v DC motor with a single source.
          Here is a simple UIFlow to check every component works correctly:
          Best regards
          • J
            jerome83136
            Hello all,
            Last part done (single power supply for M5 core + DC motor)
            I was also able to remove the PaHub by using the ExtPort (Port D). I had to change the dip switch value to:
            • Port D-1[2] = ON (to use GPIO22)
            • Port D-2[2] = ON (to use GPIO21)
            I then had to change the TOF module's port config in UIFlow to use the Port D:
            Final diagram:
            NB: DC(12v) to USB(5v) converter link
            Now let's get physcal parts printed and test it !
            Best regards
            • ajb2k3A
              ajb2k3
              Cool and thanks for sharing your progress.
              When you get everything up and running, please create a build log on Hackster.io
              J 1 Reply Last reply Reply Quote 1
              • J
                jerome83136
                Hi guys,
                New problem here: I'm unable to use this RFID reader from Seeed studio
                The reader is able to communicate by serial (9600 baudrate, 8 data bits, 1 stop bit, and no verify bit)
                I connected it with my Ext port Blue port PortC (stacked with my M5 Core Basic)
                • Reader Yellow wire (TX) --> Ext port (Port C) / PIN13
                • Reader White wire (RX) --> Ext port (Port C) / PIN14
                On UI Flow I tried this:
                When I put an RFID tag on the reader; a red led seems to indicate it detects the tag; but I get nothing printed on my M5 Core Basic screen.
                What did I wong ?
                Best regards
                • J
                  jerome83136
                  Hello,
                  Anybody here to help me on this blocking point?
                  Thank you
                  Best regards
                  • J
                    jerome83136 @ajb2k3
                    @ajb2k3 hello,
                    I would be really happy to share my project; but for this I will need some help on my last question on this topic 😉
                    Any suggestion to unblock me ?
                    Best regards
                    • ajb2k3A
                      ajb2k3
                      Have you got a micropython library installed for the reader?
                      It looks like you set up the connection but you have yet to initialise the reader and tell it to start talking.
                      • J
                        jerome83136
                        Hello,
                        The code generated by the UIflow example from my last screenshot is the following:
                        from m5stack import *
                        from m5ui import *
                        from uiflow import *
                        setScreenColor(0x222222)
                        lcd.fill(0xffffff)
                        uart1 = machine.UART(1, tx=14, rx=13)
                        uart1.init(9600, bits=8, parity=None, stop=1)
                        while True:
                        if uart1.any():
                        lcd.print((uart1.read()).decode(), 0, 0, 0xff0000)
                        wait_ms(2)
                        Do I need to add something else to this code to receive any signal from the reader ?
                        Do tyou mean UIFlow requires additional libraries to be able to communicate over serial (UART) ?
                        Best regards
                        • J
                          jerome83136
                          Hello @ajb2k3
                          I took a look on your UIFlow handbook for some examples on serial communication.
                          I found this:
                          It seems the code is almost the same than the one generated for me by UIFlow.
                          The imported libraries are the same than the ones I have in my code:
                          from m5stack import
                          from m5ui import
                          from uiflow import
                          On the example provided by my reader's provider; they import this library: " #include <SoftwareSerial.h>"
                          https://wiki.seeedstudio.com/Grove-125KHz_RFID_Reader/#play-with-arduino
                          But I think this is the implémentation for Arduino and I guess the equivalent UIFlow libraries are loaded through this:
                          from m5stack import
                          from m5ui import
                          from uiflow import
                          Do I miss something ?
                          On my side I think the reader works because when I bring a RFID tag close to it; the status led of the reader lights up.
                          But I still receive nothing on the M5 core RX PIN
                          Best regards
