UIFlow 1.6.2
UpdateLog:
Ver 1.6.2 time : 2020.08.07
firmware:
- V-Function: support Line Tracker&Tag reader..
- Image: PNG support..
- StickC-Plus beep support..
- IR unit bug fix..
- Therad mutex bug fix..
- Other bugs fix..
- Core2: Speaker support(Only support play WAV file for now)..
- Core2: Vibration motor intensity setting support..
- Core2: Checkbox widgets support..
- Core2: Slider bar widgets support..
- Core2: Bar widgets support..
web:
- Add: V function support Line Tracker&Tag reader
- Add: Core2 Slider, Bar, Checkbox component
- Fixed some bugs.
It'd be nice if there were demos for the V-function. I can't get anything done
@plusulli we had provided tutorial in the document.
When will the Desktop UIFlow version 1.6.2 be released !
@m5stack
Hellow everibody!
Realy, i'm a new one at this mater but, I like them .
I baugt some kits arduino, including the M5GO IoT Starter v1.0
I started reading all papers including, reading the procedings to configuration,
specialy the wifi connection.
At a time, I receved a message from the the UIFlow page telling me it would be better to update de firmware to the V1.6.2 version. So, I do that! Using the M5 Burner. So! After this, the M5GO was staing diferent, never could more config the wifi connection, and so on. After many times traing the M5 Burner, and other things, acidentaly I erased the firmware at my M5GO.
SO, I'm asking you, the grate masters, for your help or only if I'll go yet revive it!
This because, After the death of M5GO Stack, I traid the M5 Burner page and I get always an error message from the Java Script software. The M5GO always conneted by USB cable.Many Thanks in Advance
João Silva, Portuguese , 70 years oldThe better things for your lifes
@joão-silva what error info alert in the M5Burner ?
you could follow this tutorial to learn how to configuration wifi etc in the new UIFlow firmware version
https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython
@skink coming...soon
This is the error message from Java Script when I do save at the window " wifi config " at M5 Burner
I'll study the tutorial
Many Thanks My Friend
@joão-silva said in UIFlow 1.6.2:
Note: the drive CP210X was already installed!
@joão-silva try to open with administrator rights
Well, now I cann't continue because this ...
... well, the last weekend was hard ! I'm now iniciating as administrator; I'm definined with total control.
Unhappelly, I continue with that message but I do no why!!
Can you continue help me? Thanks a lot!!
This happen when I try to configure UIFlow from the M5Burner software, before Burning. What meanes?
This is the window at M5Burner that I'm speaking.
Is it necessary to change anything before Saving?
When I press Save, appear the error message again.
@m5stack
In the past the updates of the UiFlow IDE took a maximum of one week, now almost one month has passed the IDE software is still 1.6.1 and online is already 1.6.3 !
When will the offline version be updated !?
My Windows 10 was bloking the processo ! It is fixed. But, now I have a problem with the comunication port.
Can you interpret the imagies at top of the message, for me, please?
Thanks.
we haven't met this situation. maybe you could check if there is firewall software. or try again another PC environment.
