    UIFLOW does not save python code
    11 Posts 6 Posters 25.3k Views 2 Watching
    • M5StickFreaklerM Offline
      M5StickFreakler
      UIFLOW does not save edited python code (only Blockly).
      If you enter any python code directly in UIFlow and save it then you will be surprised if you load the code later - it is empty!
      Why?
      Just save the code as .py-file would be great.
        Thrasher
        Yes, its been so since beginning. We hope it will be implented soon
        • sysdl132S Offline
          sysdl132
          UIFlow cannot save python code.You can save .py file in visual studio.
          For Atom:115200/230400/921600
          • world101W Offline
            world101
            The only way to get custom code to save within UIFlow is to...
            • add it to the Execute block (under Advanced)
            • Create your own custom blocks with http://block-maker.m5stack.com/
              M5StickFreakler @sysdl132
              @sysdl132 Yes, but it is confusing because I can save it, but nothing is saved :-)
              • sysdl132S Offline
                sysdl132
                If you want to download visual studio,click me
                M5StickFreaklerM 1 Reply Last reply Reply Quote 1
                  @sysdl132 said in UIFLOW does not save python code:
                  No problem, already installed (I'm a developer). Its just dangerous if someone save a file in UiFlow and then nothing is in it. So maybe m5stack should disable the save button if you are in py-code. :-)
                    ajb2k3 @M5StickFreakler
                    @m5stickfreakler only the blocks are saved not micropython code. This has been the same since the beginning.
                      M5StickFreakler @ajb2k3
                      @ajb2k3 said in UIFLOW does not save python code:
                      What will you say with that? I know it is not saving micropython code - that's the point!
                      Again: If I have the python code in front of you and then save it, then it is not saved and you don't see that.
                      A good UI does not allow such things.
                      So in my opinion there are two solutions:
                      • It is not possible to use the save function if switched to python code
                      • or it saves a py-file if switched to python code
                        Thrasher
                        Just use vs code lol
                        You can run uiflow dual-box to check for m5 libraries code and simply copy strings to vs code
                          flypeek
                          Import large MicroPython scripts with UIFlow
                          https://qiita.com/ciniml/items/68bc7f362d6985efc640
