    [Solved]Exceptions & timeouts with GET Requests
    5 Posts 3 Posters 15.7k Views 1 Watching
      Foxhound
      Thanks everyone on this forum for their help. Currently finishing off my project. However, somtimes my GET request fails, and it's causing my device to crash. What's the proper way to set a timeout or catch an error?
      I'm currently trying the following.
      try:
              lResponse = urequests.get( URL , headers = self.fHeaders )
              content = ujson.loads( lResponse.content )
              return abs( content )
          except:
              return 0
      However, this doesn't seem to be solving it. Any pointers would be greatly appreciated.
      Kind Regards,
      Fox
      • m5-docsM Offline
        m5-docs @Foxhound
        @foxhound
        try:
            except:
                # print("GET failed.") # you need print some information to serial monitor. I just take an example. or write some code for catching timeout error
                pass
        M5Stack documentation URL
        https://docs.m5stack.com
          Foxhound
          @m5-docs said in Exceptions & timeouts with GET Requests:
          pass
          Thanks for your response, but a little confused with how this differs from mine?
          I'd love to do a timeout, is there a way to write a function that will timeout, similar to eventlib in Python? Or is there a different way I am supposed to be doing a get request that won't block.
            Foxhound
            @m5-docs so it turns out I was forgetting to close the response.
            try:
                lResponse.close()
            except:
                return 0
            Solved the issue.
            E 1 Reply Last reply Reply Quote 2
            • E Offline
              Efried @Foxhound
              @foxhound What about adding some hints if it fails return_code for example. I'm asking because the connection seems not to be stable...
