M5StickC: turn off screen completely
After a little bit of poking around I managed to turn off the screen:
Wire1.beginTransmission(0x34); Wire1.write(0x12); Wire1.write(0b01001011); // LDO2, aka OLED_VDD, off Wire1.endTransmission();
This turns off LDO2, and thus the backlight. To turn it back on:
Wire1.beginTransmission(0x34); Wire1.write(0x12); Wire1.write(0x4d); // Enable LDO2, aka OLED_VDD Wire1.endTransmission();
@dda Thanks! @ricardocosta can probably check to see how much current is used when backlight is off.
While I'm at it, an explanation about
M5.Axp.ScreenBreath(x);
. The code is:void AXP192::ScreenBreath(uint8_t brightness) { Wire1.beginTransmission(0x34); Wire1.write(0x28); Wire1.write(((brightness & 0x0f) << 4)); //Enable LDO2&LDO3, LED&TFT 3.3V Wire1.endTransmission(); }
What it does is it takes the value you passed, cuts it to 4 bits (0-15) and moves those 4 bits to bits 4-7. Register 28H is voltage control for LDO2 (bits 4-7) and LDO3 (bits 0-3). So the OLED is connected to LDO2.
What that 0-15 value represents is a voltage of 1.8 to 3.3V, in 100mV/steps. So
M5.Axp.ScreenBreath(0);
sets voltage to 1.8V, andM5.Axp.ScreenBreath(15);
to 3.3V. Not what we really want – as the goal was to set voltage to zero... :-)Whereas register 12H controls the state (ON/OFF) of a bunch of wires, including LDO2 (bit 2). Hence the code above.
Does your code cut the voltage to the backlight only? or to the screen as well?
To be tested but I think this turns off OLED_VDD, ie the current to the OLED. Register 10H is said to be for OLED_VPP so setting it to zero could help too.
I did a simple test: with only REG 28H the screen stays slightly warm. With both 28H and 10H, the screen cools off after a while. Hardly a scientific test, I know, but seems to point to the need to set both registers.
@dda what a wonderful work you have done! I hope this will enable @Multihelix to use M5StickC as a watch (turn off OLED after a timeout and turn on OLED on button press or accelerometer)
How are you getting 5 hours of life? it seems you would need <16 ma total drain
Are you sleeping the ESP32?
@ws1088 Funny enough I bought my M5StickC with the watch strap and all, but not because I wanted a watch – I don't wear them – but because it enables me to tie it up to my backpack when I do LoRa range tests :-)
@dda said in M5StickC: turn off screen completely:
why would you use m5stickc to do LoRa range tests? You can get LoRa chip with OLED screen. Do you connect m5stickc to a LoRa chip via I2C? or WiFi AP?
I have a lot of different LoRa chips and setups. I have one board, at 230 MHz, that I can connect through the hat connector (I need 3 pins + Vcc/GND). I have transceivers, both at 230 and 433 MHz, I connect to via RS485 (I bought a hat for that, and also some RS485 for my M5Stack cores). etc etc. The smaller the better :-)
@maxstack - Yes, I used ESP DeepSleep set to wake on Button A being pressed, but I would say that the 5 hour time was not under ideal conditions, as I occasionally woke up the device to confirm it was still working and to check the time - a resonable activity for a watch.
@multihelix Can you post a link to your watch code?
I'm looking at this thread to hopefully implement a complete screen turn off, but am not sure what register mask to use (based on quoted post)
Here is what I have, the screen is off but hard to know if the screen has actually been disabled.
void turnOffScreen() {
Wire1.write(0x10);
Wire1.write(0b00000000); // 7-3=? | 2=EXTEN | 1=? | 0=DC-DC2
Wire1.endTransmission();Wire1.begin(21, 22);
Wire1.write(0x12);
Wire1.write(0b01001011); // 7=? | 6=EXTEN | 5=? | 4=DC-DC2 | 3=LDO3 | 2=LDO2 | 1=DC-DC3 | 0=DC-DC1
Wire1.endTransmission();Wire1.beginTransmission(0x34);
Wire1.write(0x28);
Wire1.write(0b00001111); // 7-4=LDO2 | 3-0=LDO3
@klimbot: I think you have to turn LDO3 and LDO2 off, in your code only LDO2 is off. Take a look at this picture: https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc/m5stickc_05.webp
This is how I init my M5StickC in a full black screen way.
M5.begin(0,1,1); M5.Axp.SetLDO2(false); M5.Axp.SetLDO3(false);
