CAD Files of the cases?
Hi there
Where are the CAD Files to download of the cases? Would be great to have the source.
I have searched but I didn't foundBest regards Buhi
Hi Buhi,
This is what's available so far.......
https://github.com/m5stack/M5-hardware
https://www.thingiverse.com/thing:2754642
http://forum.m5stack.com/topic/59/diy-mini-proto-board
@JimiT Thank you.
I think that's enough for Solidworks and my 3D Printer ;-)
Buhi,
To make compatible PCBs we need accurate dimensions for the M5stack Proto-2.54.
The stack requires a perfect mechanical alignment to work. I am developing a plugin M5stack modulePlease provide a drawing where the hole locations and smd connector location dimensions are provided.
Thanks.
Buhi,
The 30 pin smt connector used in the M5stack has shorter pins and is different than the US commercial parts.
What is the male connector part number. Please provide a pdf drawing of the part.Thanks.
@jjcain1 Hi, I haven't seen anyone list part numbers for the headers. M5Stack seem to be the only known supplier at this time. Pin pitch is listed as 2.54 mm. Sorry I don't have a PDF drawing.
the 2*15 pin connector is a custom product, only supplied by us.
