    Neopixel units not working in uiflow 1.2
    Bug Report
    15
    23.8k
    • J
      jpilarski
      I have tried multiple M5stacks and also different ports but the neopixels don't appear to be working in UIflow no matter what I am trying. They work just fine if I jump over to Arduino and program them there but they no longer look to be working in the latest Uiflow. I am not getting an error I am just not getting any light from the neopixels. The units neopixel library was working on previous versions but I think it might be broken. Can somebody please verify this.
        I will take a look tonight. Normally they run on Port A, I will check when I get back to the bench.
          Conformed, no response to Neopixels on M5Core
          • m5-docsM
            m5-docs
            Recommend to use FastLED library instead of neopixel library
            M5Stack documentation URL
            https://docs.m5stack.com
              ajb2k3 @m5-docs
              @watson said in Neopixel units not working in uiflow 1.2:
              how do you use fast led in UIFLOW
              • lukasmaximusL
                Noted, thanks for the heads up guys, and my apologies. I will inform the team and we'll get it sorted asap. @watson they are talking about no neopixel control in uiflow not in arduino
                  Neopixel hex not working with M5Stick on Firmware 1.2.2 in UIFLOW!
                  • m5-docsM
                    m5-docs @ajb2k3
                    Hello @ajb2k3 Do you mean this unit?
                      ajb2k3 @m5-docs
                      @watson
                      Yes the Hex, was working fine before the 1.2 update.
                      • m5-docsM
                        m5-docs @ajb2k3
                        @ajb2k3 Have you connected HEX with the input direction?
                          As I said before, it was all working pre 1.2 via port A the i2c port.
                          • m5-docsM
                            m5-docs @ajb2k3
                            @ajb2k3 As a software engineer told, version 1.2.2 has fixed this bug. You can try it.
                              ajb2k3 @m5-docs
                              Works with M5STACK
                              Does not work with M5STICK!
                              • m5-docsM
                                m5-docs @ajb2k3
                                @ajb2k3 Does you keep M5Stick be lastest vesrion (v1.2.2) ?
                                  ajb2k3 @m5-docs
                                  @watson Yes,
