    PaperS3 with M5United?
    PRODUCTS
    680
    • W
      wsanders
      Has anyone gotten the PaperS3 peripherals to work with M5United?
      My program compiles OK with #include <M5Unified.h> but when I include the call to M5.begin(); at the top of my setup() code, the program crashes and is stuck in a crash/restart loop.
      For now, I have a working simple badge program here: https://github.com/wsanders/M5PaperS3-Stuff/tree/main
        felmue @wsanders
        Hello @wsanders
        please see PR on how to get rid of the crash.
        BTW: I like the little blinking dot.
        • W
          wsanders @felmue
          @felmue That PR did not work, only random lines on screen. The random lines burned an afterimage on the screen. I don't think the screen was permanently damaged; after a few cycles of leaving the screen all-black for several minutes the afterimage seems to be slowly going away.
          But you had the right idea: On further investigation I added a "#include <epdiy.h>" and the program works now.
            felmue @wsanders
            Hello @wsanders
            I am sorry I scared you and I am glad you figured it out. Thank you for letting me know.
            I am using Visual Studio Code and for me it works/worked without this include. But yes, you are correct it is mentioned in the docs to include <epdiy.h> and when I do that on my end it still works.
              felmue @felmue
              Hello again
              just wondering. There is actually a check in M5GFX.cpp about whether epdiy.h is included or not. Do you remember, did you see this error in the log (I do not):
              #if !__has_include (<epdiy.h>)
                            ESP_LOGE(LIBRARY_NAME, "M5PaperS3 need install EPDiy library");
              • W
                wsanders @felmue
                @felmue I did not see that error.
                The afterimages have gone away. Leaving the screen all black and powered off a few minutes will help clear it, this is common EPD behavior.
                • felmueF felmue referenced this topic on
