    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 252.0k Views 6 Watching
      TomSuch
      Fast and dirty minimalist application menu for M5Stack.
      Integrated applications: DHT12 - Temperature / Humidity Stopwatch I2C scanner Bluetooth BLE Beacon Simulator (iBeacon, Eddystone TLM + URL, ALTBeacon)
      Settings: display backlight
      Other: sleep mode
      I will be glad when you share the further development, I will continuously add other applications and options.
      https://github.com/tomsuch/M5Stack-SAM
      https://www.youtube.com/watch?v=I0mzvDC6M1c
      JJJ 1 Reply Last reply Reply Quote 3
      • JJJ Offline
        JJ @TomSuch
        @tomsuch
        Wow ! Nice menu system. Exactly just what was needed. Look forward to seeing how it develops over time...
        • SunWukongS Offline
          SunWukong
            SunWukong
            Hi @TomSuch , I like your SAM, have cloned it and extend it a bit.
            I have add an APP - appBME280, to read a Grove - Barometer Sensor.
            M5Stack-SAM ext. version
            appBME280
            T W 3 Replies Last reply Reply Quote 3
              TomSuch @SunWukong
              @sunwukong Super, good work. Thank you
              SunWukongS 1 Reply Last reply Reply Quote 1
                TomSuch
                Added QR-Code APP
                  TomSuch
                  Added Serial Interface for remote control:
                  Serial control at 115200 8N1 and NL&CR termination
                  bright [0-255] - display bright
                  EXAMPLE: bright 128
                  clr - clear display
                  sleep - power sleep, wakeup on BTN_B
                  qrc [text] - show QRCODE with text
                  EXAMPLE: qrc www.google.com
                  Send iBeacone message
                  ibeacon [major code 0-65535] [minor code 0-65535] [power 0-255]
                  EXAMPLE: ibeacon 1024 2048 50
                  Send Eddystone TLM message
                  eddystonetlm [voltage 0-65535] [temperature 0-65535] [pocket cound 0-4294967295] [second from up 0-4294967295]
                  EXAMPLE: eddystonetlm 100 200 300 400
                  Send Eddystone URL message
                  eddystoneurl [prefix 0-3] [power 0-255] [url]
                  EXAMPLE: eddystoneurl 1 1 google.com
                  PREFIXES:
                  0 http://www.
                  1 https://www.
                  2 http://
                  3 https://
                    TomSuch @JJ
                    @jimit Thank you for the positive bond ...
                    • JJJ Offline
                      JJ @TomSuch
                      @tomsuch
                      No problem Tom. Very much deserved !
                      Have got a wifi scan working with this under the Apps menu... but need to more spend a bit more time to get the screen output layout right... so each scan displays from the same line each time.
                      • m5stackM Online
                        Awesome, i think we should do some offical support about this good idea.
                        T 1 Reply Last reply Reply Quote 3
                          TomSuch @m5stack
                          @m5stack Thank you. I'd like to create something like a Swiss knife for makers.I like M5Stack and I'd like to create applications like a simple pocket oscilloscope, multimeter, I2C / SPI sniffer, signal generator, and so on. I think M5Stack is a platform with a lot of potential. Regards..
                            TomSuch
                            New version:
                            Added:
                            • APP - GY-512 (MPU6050) - gyro/accelerometer
                            • APP - variable speed Serial PASS-THRU USB<->UART2
                            • SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
                            • Serial Commands - WiFiScan, I2CScan
                            • m5stackM Online
                              @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
                                Kryten
                                I get errors on all
                                [code]
                                #pragma mark
                                [/code]
                                Will comment out and try again
                                  TomSuch @Kryten
                                  @kryten Please specify the error. Arduino version. Take PrintScreen.
                                  Do you have installed M5.libraries ? ESP32 libraries ?
                                  • reaper7R Offline
                                    reaper7
                                    @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
                                    APP - GY-512
                                    very nice system!
                                    APP - GY-512 works also with built-in MPU9250 :)
                                    Can You modify TIM MEASUREMENT APP?
                                    S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
                                      TomSuch @reaper7
                                      @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
                                      • JJJ Offline
                                        JJ
                                        T 2 Replies Last reply Reply Quote 0
                                          TomSuch @JJ
                                          @jimit Hi, good work. But I did not find the code on your git ...
                                          • JJJ Offline
                                            JJ @TomSuch
                                            @tomsuch
                                            Oops... sorry bout that. Have added them now....
