    AtomDTU NB-IoT
    32 Posts 2 Posters 36.9k Views
      Hello @Felix22
      ok, so it seem that the modem is registered with Swisscom, but doesn't get an IP address since AT+COPS? succeeds, but AT+CGCONTRDP fails.
      At this point I am not sure what might be the issue. Is there anything in the q.beyond portal, like a log showing some error?
      Also since you used your iPhone with that SIM card before there might be some kind of security check not accepting a connection from a different device. On the q.beyond portal, is there a way to reset / clear the data from the previous connection?
        Felix22
        Interesting, this is the response from the DigitalRepublic-SIM-Card how has no NarrowBand.
        He see the Network also...
        Now, ih have deactivated and new activated the SIM.
        Now its a "3" = "Operator forbidden" (?) (Swisscom)
        and
        1 for sunrise
          Hello @Felix22
          hmm, strange. Do you know which roaming partner (Swisscom and/or Sunrise) q.beyond has in Switzerland for NB-IoT? Maybe worth checking with q.beyond support.
            Felix22
            Many thanks.
            I will write to the support from q.beyond.
            If the connection will go on. What are the Code for an MQTT connection ?
            If i become an IP-Address, can i use the "normal" MQTT Blockly ??
            Regards,
              Hello @Felix22
              please refer to the SIM7020 documentation for MQTT commands. You can find the PDFs here - section Related Link.
              As soon as the modem gets an IP address the last AT command AT+CGCONTRDP sent by Init NB-IoT DTU block should succeed and then you can use all the other MQTT blocks.
                Felix22
                a.beyond say, she works in Switzerland with Swisscom NB.
                How can I explicit connect to Swisscom (AT-Command) ?
                  Hello @Felix22
                  AT+COPS=1,2,"22801"
                    Felix22
                    b'AT+CSQ\r\r\n+CSQ: 18,0\r\n\r\nOK\r\n'
                    men, i have a signal ?
                    b'AT+CSTT="iotsim.melita.io","",""\r\r\nOK\r\n'
                    b'AT+CSTT?\r\r\n+CSTT: "iotsim.melita.io","",""\r\n\r\nOK\r\n'
                    APN is set correct ?
                    b'AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                    Registered ?
                    b'AT+COPS: 1,2,"22801"\r\r\nERROR\r\n'
                    b'AT+COPS?\r\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
                    b'AT+CGACT?\r\r\n+CGACT: 1,0\r\n\r\nOK\r\n'
                    If i have a connection, do i become an ip-address ?
                    with the command AT+CIFSR
                      Hello @Felix22
                      it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
                      See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
                      The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
                        Felix22
                        Result:
                        b'\r\nOK\r\n'
                        b'\r\nOK\r\n'
                        b'\r\nOK\r\n'
                        b'\r\nOK\r\n'
                        b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
                        b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                        b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
                        Im a big step wider... now, i have become my ip address... :-)
                        Now i think... MQTT, next step.
                          Felix22
                          Juhuuuu !!
                          It works !
                          More Information and the solution will follow...
                          @felmue : many thanks
                            Hello @Felix22
                            I am happy to hear you got it working.
                              Felix22
                              now, i have a new problem.
                              The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
                              I see no difference...
                              The orange part is working and the tree other is not working
                              • Domainname
                              • IP-Address
                              • Dyndns
                                not working...
                                test.mosquitto.org is working fine.
                                Hello @Felix22
                                hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
                                  Felix22
                                  you mean the blocks at "Fortgeschritten" / MQTT ?
                                  over there it connects over Wlan/Wifi...
                                  Is there a MQTT-Block how i can say the RX and TX pin ?
                                    Hello @Felix22
                                    no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
                                      Felix22
                                      this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                                      But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                                      Do you also use the Atom DTU NB-IoT ?
                                        Hello @Felix22
                                        not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                                        And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                                          Hello @Felix22
                                          I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                                            Felix22
                                            Do you have a list with the Status Codes ?
                                            Signal Qualität: 16
                                            MQTT-Connection: 0
                                            Network-Registration: 7
                                            GPRS network registration
