    AtomDTU NB-IoT
    32 Posts 2 Posters 36.9k Views
      Felix22
        Hello @Felix22
        ok, so it seem that the modem is registered with Swisscom, but doesn't get an IP address since AT+COPS? succeeds, but AT+CGCONTRDP fails.
        At this point I am not sure what might be the issue. Is there anything in the q.beyond portal, like a log showing some error?
        Also since you used your iPhone with that SIM card before there might be some kind of security check not accepting a connection from a different device. On the q.beyond portal, is there a way to reset / clear the data from the previous connection?
          Felix22
          Interesting, this is the response from the DigitalRepublic-SIM-Card how has no NarrowBand.
          He see the Network also...
          Now, ih have deactivated and new activated the SIM.
          Now its a "3" = "Operator forbidden" (?) (Swisscom)
          and
          1 for sunrise
            Hello @Felix22
            hmm, strange. Do you know which roaming partner (Swisscom and/or Sunrise) q.beyond has in Switzerland for NB-IoT? Maybe worth checking with q.beyond support.
              Felix22
              Many thanks.
              I will write to the support from q.beyond.
              If the connection will go on. What are the Code for an MQTT connection ?
              If i become an IP-Address, can i use the "normal" MQTT Blockly ??
              Regards,
                Hello @Felix22
                please refer to the SIM7020 documentation for MQTT commands. You can find the PDFs here - section Related Link.
                As soon as the modem gets an IP address the last AT command AT+CGCONTRDP sent by Init NB-IoT DTU block should succeed and then you can use all the other MQTT blocks.
                  Felix22
                  a.beyond say, she works in Switzerland with Swisscom NB.
                  How can I explicit connect to Swisscom (AT-Command) ?
                    Hello @Felix22
                    AT+COPS=1,2,"22801"
                      Felix22
                      b'AT+CSQ\r\r\n+CSQ: 18,0\r\n\r\nOK\r\n'
                      men, i have a signal ?
                      b'AT+CSTT="iotsim.melita.io","",""\r\r\nOK\r\n'
                      b'AT+CSTT?\r\r\n+CSTT: "iotsim.melita.io","",""\r\n\r\nOK\r\n'
                      APN is set correct ?
                      b'AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                      Registered ?
                      b'AT+COPS: 1,2,"22801"\r\r\nERROR\r\n'
                      b'AT+COPS?\r\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
                      b'AT+CGACT?\r\r\n+CGACT: 1,0\r\n\r\nOK\r\n'
                      If i have a connection, do i become an ip-address ?
                      with the command AT+CIFSR
                        Hello @Felix22
                        it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
                        See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
                        The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
                          Felix22
                          Result:
                          b'\r\nOK\r\n'
                          b'\r\nOK\r\n'
                          b'\r\nOK\r\n'
                          b'\r\nOK\r\n'
                          b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
                          b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                          b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
                          Im a big step wider... now, i have become my ip address... :-)
                          Now i think... MQTT, next step.
                            Felix22
                            Juhuuuu !!
                            It works !
                            More Information and the solution will follow...
                            @felmue : many thanks
                              Hello @Felix22
                              I am happy to hear you got it working.
                                Felix22
                                now, i have a new problem.
                                The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
                                I see no difference...
                                The orange part is working and the tree other is not working
                                • Domainname
                                • IP-Address
                                • Dyndns
                                  not working...
                                  test.mosquitto.org is working fine.
                                  Hello @Felix22
                                  hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
                                    Felix22
                                    you mean the blocks at "Fortgeschritten" / MQTT ?
                                    over there it connects over Wlan/Wifi...
                                    Is there a MQTT-Block how i can say the RX and TX pin ?
                                      Hello @Felix22
                                      no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
                                        Felix22
                                        this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                                        But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                                        Do you also use the Atom DTU NB-IoT ?
                                          Hello @Felix22
                                          not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                                          And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                                            Hello @Felix22
                                            I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
