    LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus
    10 Posts 4 Posters 7.9k Views 2 Watching
      flex
      at initialisation, getting message:
      File "unit/lorawan.py" line 7 in __init __ NameError name 'LoRaWan' isn't defined
      does someone has a workaround?
      • felmueF Online
        Hello @flex
        it looks like a typo in UIFlow2 firmware. I proposed a PR which solves the error. However I cannot fully test the fix as I do not have the necessary hardware.
          Just a point of interest but the unit is about to be replaced with an updated version soon
            flex @felmue
            @felmue I'll check and let know, thanks
              flex @ajb2k3
              @ajb2k3 Great to know, but I hope anyway support of current version, not good to run about new versions when current version not stabilised and working. Thanks for info
              • MadeFLM Offline
                MadeFL
                Is there a way we can update the firware (I am using the EU version 868), or do we wait until the next drop of UiFlow?
                Tim
                  ajb2k3 @MadeFL
                  @madefl Wait and see what is going to happen
                  • felmueF Online
                    Hello @MadeFL
                    if you feel like it you can build the UIFlow firmware yourself. You can find the source code here.
                    • MadeFLM Offline
                      MadeFL
                      @felmue said in LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus:
                      here
                      I have followed the instructions and after changing the lorawan module as describe above (and managing to get the CoreS3 into bootloader mode, it is now loading the 'program' onto the device, with no errors.
                      Now just to get the LoRa connection working :-)
                      Many thanks.
                      Tim
                      • MadeFLM Offline
                        MadeFL
                        Just looping back on this... (sort of).
                        I found the example of using a Core device as a LoraWan gateway, and it seems the code is only availe to load into the M5Core.
                        Being as the code was for an older version than the CoreS3 I have, I have looked around for the UIflow version of that example, but am unable to find it.
                        Does anyone know if it existed and where it might be, so that I can compare it to what is available in UIFlow2 and update it?
                        Many thanks,
