<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">at initialisation, getting message:<br />
File "unit/lorawan.py" line 7 in __init __ NameError name 'LoRaWan' isn't defined</p>
<p dir="auto">does someone has a workaround?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/6081/lorawan_868-not-working-under-uiflow-2-01-on-cores3-or-sticc-plus</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 15:19:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6081.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Feb 2024 12:52:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Wed, 24 Apr 2024 19:50:53 GMT]]></title><description><![CDATA[<p dir="auto">Just looping back on this... (sort of).</p>
<p dir="auto">I found the example of using a Core device as a LoraWan gateway, and it seems the code is only availe to load into the M5Core.<br />
Being as the code was for an older version than the CoreS3 I have, I have looked around for the UIflow version of that example, but am unable to find it.</p>
<p dir="auto">Does anyone know if it existed and where it might be, so that I can compare it to what is available in UIFlow2 and update it?</p>
<p dir="auto">Many thanks,</p>
]]></description><link>https://community.m5stack.com/post/24931</link><guid isPermaLink="true">https://community.m5stack.com/post/24931</guid><dc:creator><![CDATA[MadeFL]]></dc:creator><pubDate>Wed, 24 Apr 2024 19:50:53 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Sat, 24 Feb 2024 23:33:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> said in <a href="/post/24040">LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus</a>:</p>
<p dir="auto">here</p>
<p dir="auto">I have followed the instructions and after changing the lorawan module as describe above (and managing to get the CoreS3 into bootloader mode, it is now loading the 'program' onto the device, with no errors.</p>
<p dir="auto">Now just to get the LoRa connection working :-)</p>
<p dir="auto">Many thanks.</p>
<p dir="auto">Tim</p>
]]></description><link>https://community.m5stack.com/post/24113</link><guid isPermaLink="true">https://community.m5stack.com/post/24113</guid><dc:creator><![CDATA[MadeFL]]></dc:creator><pubDate>Sat, 24 Feb 2024 23:33:05 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Thu, 22 Feb 2024 22:11:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/85723">@MadeFL</a></p>
<p dir="auto">if you feel like it you can build the UIFlow firmware yourself. You can find the source code <a href="https://github.com/m5stack/uiflow-micropython" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/24040</link><guid isPermaLink="true">https://community.m5stack.com/post/24040</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 22 Feb 2024 22:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Thu, 22 Feb 2024 18:02:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/85723">@madefl</a> Wait and see what is going to happen</p>
]]></description><link>https://community.m5stack.com/post/24035</link><guid isPermaLink="true">https://community.m5stack.com/post/24035</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 22 Feb 2024 18:02:19 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Thu, 22 Feb 2024 17:27:09 GMT]]></title><description><![CDATA[<p dir="auto">Is there a way we can update the firware (I am using the EU version 868), or do we wait until the next drop of UiFlow?</p>
]]></description><link>https://community.m5stack.com/post/24034</link><guid isPermaLink="true">https://community.m5stack.com/post/24034</guid><dc:creator><![CDATA[MadeFL]]></dc:creator><pubDate>Thu, 22 Feb 2024 17:27:09 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Wed, 14 Feb 2024 06:47:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Great to know, but I hope anyway support of current version, not good to run about new versions when current version not stabilised and working. Thanks for info</p>
]]></description><link>https://community.m5stack.com/post/23795</link><guid isPermaLink="true">https://community.m5stack.com/post/23795</guid><dc:creator><![CDATA[flex]]></dc:creator><pubDate>Wed, 14 Feb 2024 06:47:40 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Wed, 14 Feb 2024 06:39:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> I'll check and let know, thanks</p>
]]></description><link>https://community.m5stack.com/post/23794</link><guid isPermaLink="true">https://community.m5stack.com/post/23794</guid><dc:creator><![CDATA[flex]]></dc:creator><pubDate>Wed, 14 Feb 2024 06:39:42 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Tue, 13 Feb 2024 11:22:12 GMT]]></title><description><![CDATA[<p dir="auto">Just a point of interest but the unit is about to be replaced with an updated version soon</p>
]]></description><link>https://community.m5stack.com/post/23783</link><guid isPermaLink="true">https://community.m5stack.com/post/23783</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 13 Feb 2024 11:22:12 GMT</pubDate></item><item><title><![CDATA[Reply to LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus on Tue, 13 Feb 2024 11:00:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/10084">@flex</a></p>
<p dir="auto">it looks like a typo in UIFlow2 firmware. I proposed a <a href="https://github.com/m5stack/uiflow-micropython/pull/18/files" target="_blank" rel="noopener noreferrer nofollow ugc">PR</a> which solves the error. However I cannot fully test the fix as I do not have the necessary hardware.</p>
]]></description><link>https://community.m5stack.com/post/23782</link><guid isPermaLink="true">https://community.m5stack.com/post/23782</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 13 Feb 2024 11:00:33 GMT</pubDate></item></channel></rss>
