    display big numbers
    5 Posts 4 Posters 10.8k Views 1 Watching
      cepics
      Hi All,
      I'm using this sketch to display sensor value in four big number on M5 lcd...
      can someone help me to do not display the first "0"?
      es " 222" instead of "0222"
      or " 35" instead of "0035"
      0r " 9" instead of "0009"
      thanks a lot
      • RopR Offline
        Rop
        Ouch, that is ugly code. But if you absolutely must, replace this bit:
          M5.Lcd.pushRect(80*3,40,80,160,(uint16_t *)(_buf+ c0 * 80 * 160 * 2));
          M5.Lcd.pushRect(80*2,40,80,160,(uint16_t *)(_buf+ c1 * 80 * 160 * 2));
          M5.Lcd.pushRect(80*1,40,80,160,(uint16_t *)(_buf+ c2 * 80 * 160 * 2));
          M5.Lcd.pushRect(80*0,40,80,160,(uint16_t *)(_buf+ c3 * 80 * 160 * 2));
        with
          if (count >= 10) M5.Lcd.pushRect(80*2,40,80,160,(uint16_t *)(_buf+ c1 * 80 * 160 * 2));
          if (count >= 100) M5.Lcd.pushRect(80*1,40,80,160,(uint16_t *)(_buf+ c2 * 80 * 160 * 2));
          if (count >= 1000) M5.Lcd.pushRect(80*0,40,80,160,(uint16_t *)(_buf+ c3 * 80 * 160 * 2));
        Note that this code will leave 9 digits on the display if the counter wraps around, you might need to put M5.Lcd.clear(WHITE); in there if you want to prevent that, but I didn't do it because it will cause flicker.
        Just out of curiosity: what are you trying to do here?
          cepics
          Hi, tanks a lot but since I'm displaying distance with an HC-SR04 your code doesn't work for me... because the sensor can "jump" from a distance with three digit to a distance with two digit (es from 125 cm to 80cm).... and , like you say, I can't use M5.Lcd.clear(WHITE); for flickering issue...
          what I'm looking for is to "clear" only the rectangle where the digit "was"...
          mumble mumble
          thanks a lot anyway ...
            heybin
            hello, you can test
            M5.Lcd.fillScreen(uint16_t color)
            to replace clear
            • m5-docsM Offline
              m5-docs
              M5.Lcd.fillScreen(BLACK)
              M5Stack documentation URL
              https://docs.m5stack.com
