    IoT Base CATm - Core2 restarts every 3-5 min or so
    iot
    3 Posts 2 Posters 5.6k Views
    • iamjameshannamI Offline
      iamjameshannam
      Re: Core2 keeps rebooting with PoE base
      I’m guessing this is probably the same/similar issue I’m having with my Core2 and the IoT CATm base?
      What exactly do I need to do here? Please help :)
      • felmueF Online
        Hello @iamjameshannam
        the issue described in Core2 keeps rebooting with PoE base is an immediate reboot cycle within a couple of seconds (and not after a few minutes). So, no, I don't think this is the same issue.
        Can you describe what software you are running on your M5Core2? UiFlow? Arduino?
        Are you running from external power or battery?
        • felmueF Online
          do you have a SIM card in your IoT Base CatM module?
          I did some testing and from within UiFlow it seems that as part of the module initialization (e.g. catmiot = module.get(module.CATMIOT)) an AT+CPIN? command is sent repeatedly (about every 6 seconds) until the module response is +CPIN: READY. Without SIM card the module response is ERROR which means the program flow is blocked forever.
