<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IoT Base CATm - Core2 restarts every 3-5 min or so]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/3551/core2-keeps-rebooting-with-poe-base">Core2 keeps rebooting with PoE base</a></p>
<p dir="auto">I’m guessing this is probably the same/similar issue I’m having with my Core2 and the IoT CATm base?</p>
<p dir="auto">What exactly do I need to do here? Please help :)</p>
]]></description><link>https://community.m5stack.com/topic/4319/iot-base-catm-core2-restarts-every-3-5-min-or-so</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 21:12:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4319.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 May 2022 17:58:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IoT Base CATm - Core2 restarts every 3-5 min or so on Thu, 26 May 2022 21:39:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/iamjameshannam" aria-label="Profile: iamjameshannam">@<bdi>iamjameshannam</bdi></a></p>
<p dir="auto">do you have a SIM card in your IoT Base CatM module?</p>
<p dir="auto">I did some testing and from within UiFlow it seems that as part of the module initialization (e.g. <code>catmiot = module.get(module.CATMIOT)</code>) an <code>AT+CPIN?</code> command is sent repeatedly (about every 6 seconds) until the module response is <code>+CPIN: READY</code>. Without SIM card the module response is <code>ERROR</code> which means the program flow is blocked forever.</p>
]]></description><link>https://community.m5stack.com/post/17570</link><guid isPermaLink="true">https://community.m5stack.com/post/17570</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 26 May 2022 21:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to IoT Base CATm - Core2 restarts every 3-5 min or so on Wed, 25 May 2022 20:31:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/iamjameshannam" aria-label="Profile: iamjameshannam">@<bdi>iamjameshannam</bdi></a></p>
<p dir="auto">the issue described in <code>Core2 keeps rebooting with PoE base</code> is an immediate reboot cycle within a couple of seconds (and not after a few minutes). So, no, I don't think this is the same issue.</p>
<p dir="auto">Can you describe what software you are running on your M5Core2? UiFlow? Arduino?</p>
<p dir="auto">Are you running from external power or battery?</p>
]]></description><link>https://community.m5stack.com/post/17567</link><guid isPermaLink="true">https://community.m5stack.com/post/17567</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 25 May 2022 20:31:31 GMT</pubDate></item></channel></rss>
