    Arduino IDE sample sketch "UHF-RFID-JRD4035" have error
    PRODUCTS
    7.9k
    • P
      PAOPAO
      After compile sample sketch "UHF-RFID-JRD4035", Arduino IDE shows
      "no return statement in function returning non-void [-Werror=return-type]" on "RFID_command.cpp"
      UBYTE UHF_RFID::Set_the_communication_baud_rate(UWORD Pow)
      Copy_command_library(13);
      ToHex(Pow, 5, 6);
      Check_bit_accumulation();
      Send_the_modified_command();
      } <- this line have error
      If possible ,could you help me how to solve this problem ?
      I use Atom lite esp32 ,therefore my Arduino IDE setting is as follows
      Board :ESP32 Pico Kit
      Upload speed :115200
        Hello @PAOPAO
        it seems that the example code for this unit is not written very cleanly and the compilation generates a couple of warnings. But for me it compiles through (eg. no errors just warnings) and generates an executable. (Although I have no way to verify the result as I do not own this particular unit.)
        The reason for the warning is that this particular function has been defined to return an UBYTE but it doesn't.
        So if you'd like to fix that warning you could simply add a return 0; just before the functions closing bracket.
        • P
          PAOPAO @felmue
          Dear felmue san,
          Thank you for your kindly reply!!
          I will try based on your advice from now on !
          • P
            PAOPAO @PAOPAO
            Dear Feimue san
            I added "_Noreturn" command on ahead of original sketch as follows
            _Noreturn UBYTE UHF_RFID::Set_the_communication_baud_rate(UWORD Pow)
            Result : "UHF-RFID-JRD4035" can get data from IC Tag.
            --------- Serial monitor ------------
            3:02:04.513 -> RSSI :c8
            23:02:04.513 -> PC :3000
            23:02:04.513 -> EPC :e2806894000040066d70b524
            23:02:04.513 -> CRC :7084
            23:02:04.513 ->
            23:02:04.607 -> RSSI :c7
            23:02:04.607 -> PC :3000
            23:02:04.607 -> EPC :e2806894000040066d70b524
            23:02:04.607 -> CRC :7084
            23:02:04.607 ->
            23:02:04.700 -> RSSI :ca
            23:02:04.700 -> PC :3000
            23:02:04.700 -> EPC :e2806894000040066d70b524
            23:02:04.700 -> CRC :7084
              Hello @PAOPAO
              great! I am happy to read you solved the issue. And I learned something new as I didn't know about _Noreturn - thank you for letting me know.
              • Bat21B
                Bat21
                Hi Paopao,
                I am in your same situation, I have been trying to communicate UHF-RFID-UNIT with Aton Lite and I don't know the right code.
                Could you spend the code to start my project?
                Thank you
