    UIFlow 1.8.1
    21 Posts 11 Posters 64.9k Views 2 Watching
      plusulli
      the Slider problem with Remore+ is still not fixed in three country versions still the same error that no data is transferred
      addendum the error also occurred with the switch and the input function
      ok
      not ok
      • saitotetsuyaS Offline
        saitotetsuya
        There is a typo in the "Power on" block for MyCobot and MyCobot Pro.
        alt text
        • OyczEO Offline
          OyczE
          Lorawan868 - element got a wrong python lib link
          Its should be 868 not 915
          gif
          @m5stack when this will be fixed ? or again there is no issue ?
            plusulli
            the Dual-BUTTON Unit no longer works in this UIflow version.
            • m5stackM Online
              m5stack @plusulli
              @plusulli thank you feedback. it already fixed.
                plusulli @m5stack
                @m5stack said in UIFlow 1.8.1:
                Great that's how it has to be
                  Hello @m5stack
                  on M5Core2 (running UIFlow fw 1.8.1), with the boot menu option set to false, still shows the splash screen and the menu screen before actually starting the previously downloaded .py code.
                  Could you please have a look?
                  P.S. Reported here.
                  • m5stackM Online
                    m5stack @felmue
                    @felmue you could change the mode option to the WiFi mode in the boot menu. and then reboot the device it will starting the UIFlow program mode.
                      favnec5 @m5stack
                      @m5stack
                      Hello. Sorry but i don't understand. Wifi mode will display wifi ssid for wifi connection. The problem is that, in the app mode, "boot menu : false" in the M5Burner software don't hide the splash screen and the boot menu at core2 startup.
                      Thanks.
                      Thomas
                      Thomas
                        Hello @m5stack
                        I am sorry, but there is no WiFi mode for M5Core2 - or am I missing something?
                        I only see Internet Mode, USB Mode and App Mode.
                        • m5stackM Online
                          m5stack @felmue
                          @felmue actually the WIFI mode is the Internet Mode. they are same
                            Hello @m5stack
                            thank you for the clarification. However when I use Internet Mode my M5Core2 shows the UIFlow flash screen, the UIFlow menu and then connects to the UIFlow Cloud. (Which btw is what I would expect it to do in Internet Mode.)
                            As stated before, also by favnec5, is that with Start Mode set to App Mode and Boot Menu set to False M5Core2 still shows the UIFlow flash screen and the UIFlow menu before starting the previously downloaded .py code.
                            Please fix or advise.
                            P.S. the issue only is with M5Core2 - it works properly on M5Stack devices.
                              Still no way to read and write to SD cards in UIFLow on the M5Paper?
                                retro
                                Hi! When will the UIFlow Desktop be updated to version 1.8.1?
                                • NN708N Offline
                                  NN708
                                  Hello @m5stack,
                                  I want to modify the MicroPython code for PaHUB, but I found that the repository on GitHub (https://github.com/m5stack/UIFlow-Code) is outdated. Could you update this repository to the newest version?
                                    Can't connect NCIR to PaHub in UIFlow
                                    • IAMLIUBOI Offline
                                      IAMLIUBO @ajb2k3
                                      @ajb2k3 said in UIFlow 1.8.1:
                                      Thanks feedback, we will update this issue.
                                        tnkmasayuki
                                        UIFlow1.8.1
                                        The MAC address of EspNow is the MAC address of SoftAP.
                                        The Mac address of EspNow reception is the MAC address of Station mode.
                                        They are different numbers and should be unified to Station mode.
                                          ajb2k3 @tnkmasayuki
                                          @tnkmasayuki AP and Station need different mac address in order to communicate in different modes.
                                            tnkmasayuki @ajb2k3
                                            ESP-NOW uses only the MAC address of the station.
                                            However, SoftAP is displayed as your own MAC address of ESP-NOW.
                                            I want the MAC address of the station to be displayed.
                                            The problem is that the received MAC address is different from your own MAC address.
