    UIFlow 1.8.0
    31 Posts 11 Posters 89.9k Views 2 Watching
    • m5stackM Offline
      m5stack @OyczE
      @mati actually that just a button. this function just like a callback, each time you press it, the function exec one time. so it can without the variable.
        Hello @m5stack
        thank you for letting us know. I appreciate it.
        And yes, I can confirm that I can load previously saved m5f files into UIFlow 1.8.0 again.
        • OyczEO Offline
          OyczE
          Hello @m5stack
          #1
          looks like new error popup in combination of Atom Lite and OLED 1.3'' module not only Env2 make error as well.
          Simple remove 'from m5stack_ui import *' fix the problem
          #2
          Plus AtomLora DUT error ..
          File "flow/m5cloud.py", line 82, in _exec_fun
          File "<string>", line 3, in <module>
          ImportError: no module named 'base.DTU_LoRAWAN'
          #3
          LoraWan868 + Core2
          'module' object has no attribute 'LORAWAN'
          Do we have any LoraWan support in 1.8.0 ?!
          Regards
          Mati
            deathvedar
            We tried to run the LoRaWAN 868 Unit with absolut no luck.
            If i select it in the UIFlow event the frequency mask is empty while the mask of a 433 unit is pre filled.
            please, please fix this ASAP!
            • OyczEO Offline
              OyczE
              @m5stack could we get reply about uiflow support for lorawan ?
              • m5stackM Offline
                m5stack @OyczE
                @mati you could try 0001 for the mask code
                • m5stackM Offline
                  m5stack @OyczE
                  @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
                  OyczEO 2 Replies Last reply Reply Quote 0
                  • OyczEO Offline
                    OyczE @m5stack
                    @m5stack indeed it was two tabs !
                    Let me check this, thx for a hint.
                      tnkmasayuki
                      I can't stop the sound.
                      UIFlow1.8.0 + M5StickC Plus
                        stefanj9
                        Wher can I find version 1.8.0?
                        • OyczEO Offline
                          OyczE @stefanj9
                          • OyczEO Offline
                            OyczE @m5stack
                            @m5stack hmm no luck one tab and still error
                            but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                            from base.DTU_LoRAWAN import DTU_LoRAWAN
                            into
                            from base.DTU_LoRaWAN import DTU_LoRaWAN
                              plusulli
                              In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
                              • m5stackM Offline
                                m5stack @plusulli
                                @plusulli sorry. that is a mistake. draw the slider to the preview box. workspace will auto create print block and variable
                                • m5stackM Offline
                                  m5stack @OyczE
                                  @mati I think the module name is from base.DTU_LoRaWAN import DTU_LoRaWAN......a is lowercase
                                  • OyczEO Offline
                                    OyczE @m5stack
                                    @m5stack said in UIFlow 1.8.0:
                                    This is a problem in the UiFlow, after importing lorawan init in the code we have LoRAWAN.
                                    And what a supprise its fixed now ;)
                                    Day ago was
                                    what a nice silent fix =]
                                      plusulli
                                      in the german version of UIflow Remote+ the slider function is faulty in the english version it is ok i searched for a long time until i found it0_1626729513974_slider.jpg
