    UIFlow 1.8.0
    31 Posts 11 Posters 92.3k Views 2 Watching
      ajb2k3 @OyczE
      @mati
      @mati said in UIFlow 1.8.0:
      @m5stack just a one small suggestion, maybe development sprint or deployment should be done at monday then we are not losing weekend to be frustration.
      This I wholeheartedly agree with!
        anvalin
        • m5stackM Offline
          m5stack @John7
          @john7 thank you feedback. we already fixed the issues. pls try again.
          • m5stackM Offline
            m5stack @OyczE
            @mati actually that just a button. this function just like a callback, each time you press it, the function exec one time. so it can without the variable.
              Hello @m5stack
              thank you for letting us know. I appreciate it.
              And yes, I can confirm that I can load previously saved m5f files into UIFlow 1.8.0 again.
              • OyczEO Offline
                OyczE
                Hello @m5stack
                #1
                looks like new error popup in combination of Atom Lite and OLED 1.3'' module not only Env2 make error as well.
                Simple remove 'from m5stack_ui import *' fix the problem
                #2
                Plus AtomLora DUT error ..
                File "flow/m5cloud.py", line 82, in _exec_fun
                File "<string>", line 3, in <module>
                ImportError: no module named 'base.DTU_LoRAWAN'
                #3
                LoraWan868 + Core2
                'module' object has no attribute 'LORAWAN'
                Do we have any LoraWan support in 1.8.0 ?!
                Regards
                Mati
                  deathvedar
                  We tried to run the LoRaWAN 868 Unit with absolut no luck.
                  If i select it in the UIFlow event the frequency mask is empty while the mask of a 433 unit is pre filled.
                  please, please fix this ASAP!
                  • OyczEO Offline
                    OyczE
                    @m5stack could we get reply about uiflow support for lorawan ?
                    • m5stackM Offline
                      m5stack @OyczE
                      @mati you could try 0001 for the mask code
                      • m5stackM Offline
                        m5stack @OyczE
                        @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
                        OyczEO 2 Replies Last reply Reply Quote 0
                        • OyczEO Offline
                          OyczE @m5stack
                          @m5stack indeed it was two tabs !
                          Let me check this, thx for a hint.
                            tnkmasayuki
                            I can't stop the sound.
                            UIFlow1.8.0 + M5StickC Plus
                              stefanj9
                              Wher can I find version 1.8.0?
                              • OyczEO Offline
                                OyczE @stefanj9
                                • OyczEO Offline
                                  OyczE @m5stack
                                  @m5stack hmm no luck one tab and still error
                                  but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                                  from base.DTU_LoRAWAN import DTU_LoRAWAN
                                  into
                                  from base.DTU_LoRaWAN import DTU_LoRaWAN
                                    plusulli
                                    In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
                                    • m5stackM Offline
                                      m5stack @plusulli
                                      @plusulli sorry. that is a mistake. draw the slider to the preview box. workspace will auto create print block and variable
                                      • m5stackM Offline
                                        m5stack @OyczE
                                        @mati I think the module name is from base.DTU_LoRaWAN import DTU_LoRaWAN......a is lowercase
                                        • OyczEO Offline
                                          OyczE @m5stack
                                          @m5stack said in UIFlow 1.8.0:
                                          This is a problem in the UiFlow, after importing lorawan init in the code we have LoRAWAN.
                                          And what a supprise its fixed now ;)
                                          Day ago was
                                          what a nice silent fix =]
                                            plusulli
                                            in the german version of UIflow Remote+ the slider function is faulty in the english version it is ok i searched for a long time until i found it0_1626729513974_slider.jpg
