UIFlow 1.7.5
Ver 1.7.5 time : 2021.04.16
v1.7.5
new features
- IoT Cloud support:
- Azure IoT SAS token generated by the device.
- machine: * CAN support(Experimental stage).
- COM.X * COM.LoRaWAN support.
- M5MQTT: * Support wildcard #&+(Experimental stage)
Bug fix:
- Core2 APP list bug fix.
- Others bug fixed
Could we expect in near time uiflow support for the 4Relay Unit, this would be reallly great
1.7.5 is supporting only COM.X LoraWan 470 and 915 modules but not the 868 MHz version M031-C?
@moe1979 we will push it and speed up its progress. thank you feedback
Hi @anvalin ,
Sorry about that, since the M031-C module firmware version is relatively low, some AT commands do not match the AT user manual, so they are not supported yet. -
@iamliubo Thanks for the info. I wonder about wether it's going to be possible to upgrade firmware of said LoraWAN module M031-C. How can this be done?
@IAMLIUBO is the Watch dog timer a system WDT or a Task WDT?
@ajb2k3 system WDT.
@anvalin It's possible.But I did't test, I will let you know,if I test it.
@iamliubo Thank you.
