    UIFlow 1.7.1
    20 Posts 10 Posters 40.3k Views 2 Watching
    • m5stackM Offline
      UpdateLog:
      Ver 1.7.1 time : 2020.12.29
      firmware:
      • Add: Core/Fire/Core2: servo2 support.
      • Add: Atom H·Driver..
      • Fixed: Core2 COM.LTE M-BUS power(5V) conflict bug..
      • Fixed: Other bugs.
      This update only provides CORE, FIRE, CORE2, ATOM LITE/MATRIX firmware.
      StickC, CoreInk and other device firmware versions will be updated later.
      • L Offline
        luis
        The hardwares block section for Fire only contains power option, no RGB, IMU and speaker blocks, these options are available for the core basic that does not have that hardware, please check it
        • O Offline
          Ove
          I installed UIFlow_Core2 version v1.7.1_core2 on my Core2 and now I have no power on port A.
          If I add "power.setBusPowerMode(0)" in the Python tab before any Units are initialized the power is returned but I can not do this with blocks.
          The power is restored until the Core2 is reset.
            houkensjtu
            I found the "Advanced" function group is missing in the Web version of UIFlow 1.7.1. Is it relocated to somewhere??
            sodokuS 1 Reply Last reply Reply Quote 0
            • sodokuS Offline
              sodoku @houkensjtu
              @houkensjtu I can still see it
              • sodokuS Offline
                sodoku
                @m5stack using on 1.7.1 on the Fire makes the speaker quite noisy.
                  @m5stack Please remove the following from the Coreinks H.A.T list as they are not physically compatable with the core in.
                  JoyC,
                  RoverC,
                  PuppyC,
                  BugC
                  BeetleC
                  CardC
                  • m5stackM Offline
                    m5stack @ajb2k3
                    @ajb2k3 thank you for feedback. we will check that.
                      teiafra
                      @m5stack said in UIFlow 1.7.1:
                      COM.LTE
                      Is the COM.LTE connectivity supported only in Core2 and not Core (Basic)?
                      If so, when extended also to Core?
                      • L Offline
                        luis
                        Please add RGB, Speaker and IMU blocks in hardwares section for the M5fire device.
                        • m5stackM Offline
                          m5stack @teiafra
                          @teiafra core supported LTE connect UIFlow too.
                            teiafra @m5stack
                            @m5stack thanks but then I'm not able to follow the procedure shown here on Twitter (showing from M5Burner, right?) aimed to pass the APN to the module. Currently I'm on UIFlow 1.7.0.
                            I posted a topic also here Can you help me?
                            • m5stackM Offline
                              m5stack @teiafra
                              @teiafra which step you stuck?
                                teiafra @m5stack
                                @m5stack:
                                On the Core display I am a able to select COM.LTE as additional connectivity as shown here.
                                BUT the next picture 0_1610609391974_M5Burner2.jpg (I guess taken from M5Burner configuration, right?) is different in my case because it shows only WiFi, while the APN section is missing 0_1610608430876_M5Burner.jpg.
                                The final result is that if I select on the Core display COM.LTE and reboot it fails to connect. 0_1610608668641_COM.X attempt.jpg.
                                Please note that the modem is working fine, since I'm able to drive it with my UIFlow code (via AT commands) moving data back and forth perfectly.
                                My ultimate need is to use the UIFlow MQTT client not through the WiFi but natively through the mobile connection.
                                THANKS!
                                • G Offline
                                  Gaviota @m5stack
                                  @m5stack
                                  @ove said in UIFlow 1.7.1:
                                  I detected a similar problem with the Core2 and UIFlow 1.7.1
                                  Testing with the ENV- and the TVOC/eCO-units at port A of the Core2 drives it into the I2C-error message "I2C bus error(19)". After rolling back the Core2 to UIFlow 1.7.0 these units works with the Core2.
                                  I think there must be a I2C-bug in UIFlow 1.7.1 for the Core2, at least for port A.
                                  OyczEO m5stackM 2 Replies Last reply Reply Quote 0
                                  • OyczEO Offline
                                    OyczE @Gaviota
                                    @gaviota said in UIFlow 1.7.1:
                                    @m5stack
                                    Yep check my finding
                                    https://community.m5stack.com/topic/2663/core2-uiflow-bottom2-support/14
                                    • m5stackM Offline
                                      m5stack @Gaviota
                                      @gaviota yeah... that is a bug. we will fix it in the next version
                                      • felmueF Online
                                        Hi guys
                                        UIFlow 1.7.1.1 for M5Core2 is out and it seems to fix at least the no power issue on port A.
                                        @m5stack : is there anything else that has been fixed on 1.7.1.1? Just curious. Thanks.
                                        Happy Stacking!
                                        • m5stackM Offline
                                          m5stack @felmue
                                          @felmue I mean. in the v1.7.1.1(for core2) version,we fixed the default(WIFI MODE) M-BUS 5V power don't open in the v1.7.1. but when you use the LTE Network Over COM Mode. you need to use it to extend DC power input else the M-BUS will lose power.
                                          For more information you could refer this tutorial :
                                          https://docs.m5stack.com/#/en/quick_start/comx_lte/network_over_com
                                          • felmueF Online
                                            Hello @m5stack
                                            thank you for the clarification. I appreciate it.
