    [M5Paper] UiFlow support
    Scheduled Pinned Locked Moved Features Wish List
    33 Posts 12 Posters 102.2k Views 6 Watching
    • OyczEO Offline
      OyczE
      When we can see full or beta test support for Μ5Paper in UiFlow ?
      1 Reply Last reply Reply Quote 7
      • ZontexZ Offline
        Zontex
        This is one of our highest priorities and we are working on it, we don't have a final date yet but once we have updates and dates in which version we will release the support, we will keep you guys updated.
        • OyczEO Offline
          OyczE @Zontex
          @zontex so maybe like was with core2 some beta flow could be published, then more ppl will gonna test it and report here what is wrong.
          • B Offline
            ben.myburgh
            Any update on this? Arduino IDE support is limited as is...
            • OyczEO Offline
              OyczE
              @Zontex @m5stack any update about M5Paper ?
              • OyczEO Offline
                OyczE @ben.myburgh
                @ben-myburgh said in [M5Paper] UiFlow support:
                i think we have micro basic support in Arduino, base on https://docs.m5stack.com/#/en/quick_start/m5paper/quick_start_arduino
                we can use M5EPD in basic operations.
                • OyczEO Offline
                  OyczE
                  @Zontex btw the Arduino example Wake and BM8563 should be a clone ?
                    @Zontex why have 2 seperate API's for the Coreink and the EPD, Could you not merge most of the API's into one unified e-ink api?
                    ZontexZ 1 Reply Last reply Reply Quote 2
                    • OyczEO Offline
                      OyczE
                      bump
                      @Zontex there is any chance to get some update ? its starting a bit sad there is grate pice of hardware already at customers home without core UIFlow support ..
                      • OyczEO Offline
                        OyczE
                        Since @Zontex is away maybe @lukasmaximus or @m5stack could give us some update.
                          Medy
                          Well as long as it comes ... ideally 2021 ... im cool ... was just afraid there would be no support at all ... since I dont plan on learning C or using arduino ide ....
                          Hopefully this is just the start of bigger screens.... I would love to have a bigger m5 lcd version as well
                          • ZontexZ Offline
                            Zontex @ajb2k3
                            @ajb2k3 regarding the API difference, we are actually working now to merge them together into one API.
                            @Mati @Medy @ben-myburgh Sorry guys ! for some reason I didn't get a notification over this post, I'll follow up on the progress and keep you guys updated. seems this is the highest priority we currently have.
                            • ZontexZ Offline
                              Zontex
                              Guys, good news - the estimated release of this support is by the Chinese new year holiday which will be in approximately 2 weeks from now :)
                              OyczEO 1 Reply Last reply Reply Quote 1
                                @Zontex sweet, I will get to see how my guesses have worked out.
                                • OyczEO Offline
                                  OyczE @Zontex
                                  @zontex said in [M5Paper] UiFlow support:
                                  nice to hear ! I am disappointed by the fact that the product appeared in the store and only after more than a month does it receive the advertised functionality.
                                    Hello guys
                                    today in M5Burner I discovered an Alpha version of UIFlow for M5Paper. Already seems to work reasonably well.
                                    Cheers
                                      doubleness
                                      @felmue Hey, are you able to run the code on your device? Not sure what I am doing wrong, I burned UiFlow alpha version, and connected to my device, also it seems like code is being uploaded to m5paper device, and screen refreshes probably restarting, but nothing shows up in the screen.
                                      Everytime I try to upload the code I get warning ' Lack block "Set screen set show" or "Set screen parital show" '
                                      Not sure what I am doing wrong, any idea?
                                      world101W ajb2k3A 2 Replies Last reply Reply Quote 0
                                      • world101W Offline
                                        world101 @doubleness
                                        @doubleness said in [M5Paper] UiFlow support:
                                        You need to have one of those blocks in your program to update the screen. They are under UI, then Screen in uiFlow.
                                          ajb2k3 @doubleness
                                          You need to have the "Set Screen Show" block as the information is only stored in memory and not drawn to the screen until set screen show or set screen partial show is called.
                                            doubleness
                                            @world101 @ajb2k3
                                            Thank you guys it works! You saved me :) ... finally I can switch to micropython, programming using arduino IDE was kind of slow and painful
