    Traceback on AtomMatrix when running example
    7 Posts 3 Posters 6.8k Views
      mb
      Hi all,
      I am a newbie to M5Stack, just got my AtomMatrix and a few other goodies.
      I followed the instructions
      https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start_uiflow
      And ran the example code
      https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Core/Atom/Atom Matrix
      Then I receive an error on the serial console and AtomMatrix shows a red X
        File "flow/m5cloud.py", line 82, in _exec_fun
        File "<string>", line 7, in <module>
        File "units/_rgb_multi.py", line 47, in set_screen
      IndexError: list index out of range
      UIFlow Web v1.4.5
      AtomMatrix v.1.6.5
      M5Burner 2.1.6
      Any ideas how to fix this?
      Mike
        Hello Mike
        I don't know if it helps, but I wouldn't mix UIFlow versions. Try selecting beta in UIFlow Web which should match the UIFlow firmware v1.6.5 on your M5AtomMatrix.
          mb
          Thanks, I erased and re-flashed the AtomMatrix, now using v1.6.5 on device and web editor.
          A simple test program is working:
          Switch all LEDs red and green in loow
          But the official example from GitHub is failing with v1.6.5 (web + firmware).
          alt text
          • m5stackM Online
            thank you feedback, we will fix it as soon as possible.
              Hello Mike
              it looks like the AtomMatrix example has been replaced and works now. (And yes, the previous example was broken for me too.)
              Cheers
                mb
                Thanks!
                • m5stackM Online
                  it is an old version program compatible problem. now we updated a new example.
