Subcategories
    125 Topics
    A
  • 211 Topics
    robskiR
    @GiovanniCaenazzo disconnect M5Dial press and hold boot button at the back ofM5Dial - in the middle of Stamp Controller - it is very gentle switch connect M5Dial to USB M5Burner should detect com port in boot mode
  • 11 Topics
    A
  • JSON AWS Topic decode
    ajb2k3A
    Is your Core connected to the WIFI ? By this I mean do you have the SSID and password blocks in your code? I cant tell from this snippet what your code is doing and need to see the full code in order to help.
  • Can't Run the Config util
    11
    10k Views
    J
    @holofloh Thanks very much for this info.. Yes I agree, my Windows 11Pro has no facility to set a VID or PIN in the FTDI driver settings but it does at least appear to be the correct / identical driver as is recommended by the docs on this site that I am now, and have been using for this M5StickCPlus V1.1 device..
  • Uiflow 2 wireless conected with uiflow
    1k Views
  • ATOM S3 with UiFlow - module M5 or M5Stack
    5k Views
    ajb2k3A
    @forestial I'm working on the docs at the moments and currently logging the API's but as you noticed, it is hard work to find them.
  • M5STack Tough in reboot loop when using UIFlow - Duplicated post
    3k Views
    I
    Thank's that solved it!
  • i2c library bug
    4k Views
  • 0 Votes
    3k Views
    Z
    Thank you! As it turned out, the main problem was that if in a program on UIFlow 2.0 (block mode) you create a variable named "state" and assign it 0 during initialization, then the controller starts to behave inappropriately (hangs, new programs either do not load or load but do not work , there are problems described in the previous post). It only helps to re-flash the controller using M5Burner and load into it a program in which there are no omissions of a variable called "state".
  • This topic is deleted!
  • How to save the last API key?
    5k Views
    Matej's WorkshopM
    Ohhh! Okay. Thanks.
  • "Unknown wifi error 0x0005"
    5k Views
    Matej's WorkshopM
    Hello, 8 months and still no reply!? Could you please send the code or is it already fixed?
  • Managing UIFlow buttons which disappear from screen but still exist
    ajb2k3A
    Not unless you leave UIFlow and use Micropython Directly with the VSCode, Thonny, or Mu editors.
  • Remote+ update values from m5stack core2 back to web ui?
    1k Views
  • Centre a label on M5Stack
    4k Views
    ajb2k3A
    @holofloh wow, I have never considered this, thanks for posting. I will add it to my guides.
  • 0 Votes
    3k Views
    D
    I have the same problem: yes - flashed firmware yes - wifi is setup (I set it up in m5burner the same way it's been working for lots of other devices, am I missing a step?) maybe it can access the UIflow2 server - how can I tell? yes - I'm trying to use uiflow2, not uiflow1 in the browser yes - I've looked at the connection settings, can't manually add it using the mac address, have no way to find the token (doesn't show up in m5burner the way old devices do)
  • CAN BUS Error with M5Stack and COMMU Module
    1 Votes
    4k Views
    E
    Solved with the code ;-) message = com.commu_can_read_message(0) hex_list = [] for b in message: hex_str = hex(b)[2:] if len(hex_str) < 2: hex_str = '0' + hex_str hex_list.append(hex_str)
  • Int to Float conversion
    7
    7k Views
    ajb2k3A
    Use the math function block to convert in to float then use a text block to convert to string?
  • UIFlow on Linux with Chrome not loading or saving Flow files
  • Unable to create simple EZData entries on M5Stack Atom Matrix
    8
    9k Views
    A
    Which firmware version are you using? | Experienced problems pushing data to EZData with 1.9.8 on Atoms. Reproduceable error not occuring after reverting to firmware 1.9.7.
