I bought and tested an I/O expansion unit called U011-B.
As a result, I was able to successfully read four I/O signals from the M5StickC Plus from U011-B during using WiFi.
I am using the M5StickC Plus and want to use the following functionalities simultaneously:
However, I realized that when WiFi is in use, only up to three analog inputs can be used.
Question 1:
Is there a way to use four analog inputs while using WiFi?
Question 2:
As a solution for not being able to use four analog inputs, I found an I/O expansion unit called U011-B.
https://www.electromaker.io/shop/product/extend-io-2-unitstm32f0
This is designed for M5Stack, but is it also compatible with M5StickC Plus?
