@teastain Today I will try connecting up the 5V piece to it . Thanks for the help
Best posts made by leaguen
RE: Power needed
Latest posts made by leaguen
RE: Power needed
RE: Power needed
@teastain Gotcha so If I give 5v to the 5V connecter the bottom 5v connecter will output 5V (I am rereading this and god I hope you understand that.) and the ir sensor is a HC-SR501
RE: Power needed
@teastain I have it powered off of the 3v3 connector, and its an IR sensor to detect motion. operation voltage of 5V-20V.
RE: Power needed
@teastain gotcha, so I need to find another way to power the sensor.
RE: Power needed
@teastain Got it, I soldered a lead to the 5V connector in the picture, but it wasn't supplying power, so I thought the bottom one would be no different. Also I bought mine in a pack of 5 so it does not come with one.
RE: Power needed
@teastain Thanks can I solder directly to the 5v connector at the bottom of the stamp or do I need the groove connector for that?
Power needed
Is there any way to get the 5V connecter to supply power to a motion sensor using the M5Stamp?
RE: esp32 to usb driver issues.
@robski I have tried it with a different usb to ttl bridge with the same results, and m5burner gives me the exact same error as arduino IDE
